a little help with old rockford 800.2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 3rd February 2014, 05:46 PM   #1
tiomilo is offline tiomilo  Costa Rica
Default a little help with old rockford 800.2
hi mighty gurus i'm here asking for your extremely large knowledge. just finish to rebuild a vintage Punch 800.2 new outputs new psu mosfets and few smd resistors and transistors by the book, now is working smoothly idle @ 0.58 amp consumption. but at few minutes getting hot @ 85 c after 5 minutes running at 4 ohm per channel. is this a bias problem or mismatch/ low quality components perhaps ? outputs are combined IRF9640 by Vishay IRF640N by IR thank's in advance.
Old 3rd February 2014, 06:15 PM   #2
timwebb is offline timwebb  United States
I think this amp have to use 640's the 640n will not function right if I remember right..
Old 3rd February 2014, 08:43 PM   #3
Interesting ! but have replaced before 640's for 640N and have no issues. maybe they change something. btw anyone knows where i can get those original IRF640 beside eBay ? most of them are fake ones. tyvm.
Old 3rd February 2014, 09:09 PM   #4
86boy is offline 86boy  United States
Digikey
http://www.digikey.com/product-search/en?vendor=0&keywords=irf640pbf
Those what you are looking for?
Old 4th February 2014, 05:00 AM   #5
Yes. Thanks a lot
Sent from my GT-I9300 using Tapatalk
Old 4th February 2014, 08:11 AM   #6
Tim is correct the IRF640N'S will cause problems in Rockford amps..
The IRF640PBF are the ones you want
You can try the following suppliers
Digikey,Mouser, Arrow, Future ect..
Old 4th February 2014, 01:50 PM   #7
seankane's Avatar
I have heard this many times but never experienced it.
I have used 640N and 9640N in amps many times and have had zero issues. There is still amps working that I have repaired years ago with the "N" FET's.
I don't think you would want N and non N in the same channel as I have never tried that.
How did you set the bias?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 4th February 2014, 04:06 PM   #8
Bias set at .58 amp at idle. Less will cause distorted sound more will fry it all. Already ordered those 640PBF. Will test and report.
Old 5th February 2014, 12:23 AM   #9
Check for bias runaway by turning the amp on COLD and check the B+ current (0.58A is what you said) then let it sit with NO SIGNAL for an hour, then check to see if the B+ current has increased more than COLD. Check to see that the bias tracking transistors on each channel are in contact with the heatsink. I think they are TO-92 devices. If the HOT bias is too high, just set it lower when COLD.
To check the output circuits, measure the efficiency. Run at full power both channels (Pout), measure B+ voltage and current, calculate the input power Pin=V*I.. If the efficiency (Pout/Pin) is more than 60%, your amp is ok.
Old 5th February 2014, 01:44 AM   #10
Ok already changed the 640N and place 640PBF. Cold idle amp decreased to 0.28 running full power for 12 minutes n'd almost burn my hand @89 test amp consumption was , .89 amp hot. If i set lower bias sound at low volume is kinda distorted. All the bias transistors msp A06 and the mspA56. the efficiency test. Less than 50% =\
Rockford 800@2 help please joesch1999 Car Audio 5 18th February 2013 12:22 PM
Rockford Fosgate Power 800.4 seankane Car Audio 71 17th January 2012 08:43 PM
Rockford Fosgate 800 a2 mike49504 Car Audio 1 8th July 2011 07:33 PM
Rockford Fosgate 800.2 Brain Fried Car Audio 2 16th April 2010 06:14 PM
Rockford Fosgate Power 800.4 lostamps Car Audio 6 2nd January 2008 01:21 PM
Copyright 1999-2017 diyAudio
