a little help with old rockford 800.2 - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 5th February 2014, 01:33 AM   #11
seankane's Avatar
The bias transistor is the MPS6521 in line with the output FET's on the MESHA board but not soldered to it.
The A06 and A56 are the drivers for the outputs.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 5th February 2014, 01:37 AM   #12
tiomilo is offline tiomilo  Costa Rica
Thanks again! Gonna replace all before next test.
Sent from my GT-I9300 using Tapatalk
Old 5th February 2014, 06:16 PM   #13
The bias drift might be improved if you find the bias tracking transistors near the MESA/Heatsink and bend them over to make contact with the hot heatsink. Use thermal grease if you have it. It will be a NPN transistor, probably MPSA06 or MPS6521.
The heatsink will go up to 90 degrees celcius and thermal protect when run at full power so that does not sound so bad. The efficiency could be better. Make sure you measure with about 1% THD clipping, 1kHz, and measure the B+ voltage right at the amp input terminals. The method of current measurement must be accurate - not just reading the dials on an ASTRON. Even so, if it doesn't blow up at full power and makes it to thermal I think you fixed it ok and would go ahead and run it.
Old 7th February 2014, 05:14 PM   #14
thanks a lot ! already replace MPSA06, MPSA56 and biasing MPS6521 on both channels now is running like charm, a little warm @ full power. consumption decreases to 0.035 at idle cold and 0.112 idle warm, very clean sound an plenty power !! thank you people !
Rockford 800@2 help please joesch1999 Car Audio 5 18th February 2013 11:22 AM
Rockford Fosgate Power 800.4 seankane Car Audio 71 17th January 2012 07:43 PM
Rockford Fosgate 800 a2 mike49504 Car Audio 1 8th July 2011 06:33 PM
Rockford Fosgate 800.2 Brain Fried Car Audio 2 16th April 2010 05:14 PM
Rockford Fosgate Power 800.4 lostamps Car Audio 6 2nd January 2008 12:21 PM
Copyright 1999-2017 diyAudio
