old massive amp
old massive amp
Old 1st February 2014, 03:42 PM   #1
ultra is offline ultra
ultra's Avatar
Default old massive amp
I got this amp for repair, and it was drawing too much current. There are 4 driver modules and each driver module drives 6 fets, 4 x IRF9640 and two defaced fets.
Does anyone knows what fets are those?
Its a D 400X model.
Old 1st February 2014, 03:45 PM   #2
JonSnell Electronic is online now JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Make and model could be useful.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 1st February 2014, 07:46 PM   #3
evianamp2011 is offline evianamp2011  United States
evianamp2011's Avatar
They appear to be in circuit with the 9640's so I would assume they are 9640's or subs that their part # got scratched off. It was repaired, as you can see they used a RED dot on those two fets. They should of replaced all the fets instead of just two.
Tek TDS1002B, Rigol DS1052E, Keithley 2015THD, Fluke 87-V 83-V & 111, DC Clamp meter, APS 90a 13.6v PS, Adjustable 0-30v/0-5a PS.
Old 1st February 2014, 11:53 PM   #4
ultra's Avatar
The red dot was done by me in order to track their position. The remaining good defaced fets test as N ch in my component tester.
Old 2nd February 2014, 07:45 PM   #5
jerluwoo is offline jerluwoo  United States
jerluwoo's Avatar
Seems it shouldn't have 4 p channel and 2 n channel. Should be 3 and 3. Someone scratching out part numbers is a sign of some seriously shady work. Generally the use of irfp9640 would be paired with irfp640. But then again from the looks of the pc board all the drains appear to be connected together, indicating they are all the same. Either way it looks like its not gonna be fun, good luck.
Old 4th February 2014, 04:42 PM   #6
tiomilo is offline tiomilo  Costa Rica
i have seen some class D amps with 3 P channel mosfets and 2 N channel looks like yours have 4 P and maybe 2 N channel, but only need to measure Voltage @ source pin #3 if it is a classic class D build Korean design should be Vcc+- at IRF9640 and Vcc- at mystery ones presuming those are IRF640 N channel mosfets. source pin #2 should be output rail with their appropriate resistors.
Old 4th February 2014, 06:48 PM   #7
ultra's Avatar
I confirm the amp works fine, even without one bank of fets.
I also confirm there are hi and low side pulses on each bank.
All i need to do now is to find the part number of the N fets, or else i have to replace them in all 4 banks (say with IRF640), that is 8 fets in total.
old massive ampHide this!Advertise here!
100W chip amp using massive parallelization cuallito Chip Amps 10 1st April 2011 11:07 PM
Massive P3000.1 massive DC offset amc32 Car Audio 5 16th March 2011 05:40 PM
Massive amp modification - basic questions - Rotel RB991 donor inteificio Solid State 19 1st December 2010 08:13 AM
massive board-wide amp group design/build...... unclejed613 Everything Else 5 8th April 2009 11:06 PM
DIY sub: massive driver needs big amp for cheap! levine Subwoofers 6 22nd March 2002 06:52 PM
Copyright ©1999-2017 diyAudio
