Pls identify these ICs
Old 9th January 2014, 08:57 AM   #1
nonprof is offline nonprof
Default Pls identify these ICs
Hello Again!
Could somebody tell me the part number of these encircled ICs, pls see attached file. Thank you very much!
I start learning how to fix driver board, previously I just replaced it.Click the image to open in full size.
Old 9th January 2014, 01:38 PM   #2
Perry Babin is offline Perry Babin  United States
Does either of the 8-pin ICs have a resistor connected directly between pin 8 and either pin 1 or 7?
Can you read the numbers on the 14 pin IC?
Old 10th January 2014, 01:47 AM   #3
ohh Im sorry Perry. They have part numbers, I thought it was tampered. It is LM6172 and LM292, 14pins is 74HC02.
Thanks again!
Old 10th January 2014, 04:54 AM   #4
timwebb is offline timwebb  United States
massvie amp?
Old 10th January 2014, 05:44 AM   #5
Originally Posted by timwebb View Post
massvie amp?
Locally, they called it as Magus amp:-) I dont know what's in the US version. Yeah it's look like a massive amp for its PCB color and SMT layout.
Old 30th January 2014, 01:25 AM   #6
Hello!
Please help it takes a long time to repair this driver board. Somebody tell me what is the part number of big IC 14pins? I know it is 74HC02 NOR gate but when I replaced it, my amp keeps burning.
I also confused to the orientation of this IC in the driver board, If I connect the pin 14 to VCc, 7 is GND which is normal, the output of the NOR gates connects to other NOR gate and input itself. If I reversed the orientation they are feasible but pin 14 is now GND and 7 is VCC.
I really confused...is there logic IC that has different Gate orientation?
Thanks! If somebody will share their schematic...kindly do it as badly needed.
Kindly check the first post for the picture of the amp.
Old 30th January 2014, 06:27 AM   #7
ohhh..I think this is 74HC00 NAND GATE. pinout is exactly to my PCB and the power supply, application will be similar seems they are universal gates. Thanks!
Old 30th January 2014, 06:28 PM   #8
I think we need to make a sticky of parts conversations and driver board pictures.
Old 3rd February 2014, 02:38 AM   #9
The driver picture is in the first post attachment. By the way it works now...I used NAND gates since IC pinout had match the PCB layout.
Pls identify these ICsHide this!Advertise here!
Help to identify these Stanton cartridges pls! gaborbela Swap Meet 0 19th November 2013 11:47 AM
Pls help identify resistors on pcb of a Mark Levinson 23.5 Rodeodave Solid State 0 16th June 2011 07:10 PM
Vintage Luxman CDP - help me identify my DAC pls.. coolnose Digital Source 3 10th October 2010 03:03 PM
pls help identify magnet type of speaker! tubo Multi-Way 10 5th April 2010 03:38 AM
Best place to identify components, ICs,..ect? cancerkazoo Parts 7 7th October 2004 12:33 PM
