Hi!
I have a box full of new IRF1010 FETs and most of the Korean amps use 50N06 (RFP,STP,FQP etc.) in power FETs.
Could it be possible to replace those 50N06 with IRF1010 and what kind of other modifications it would need...gate resistors..something else??
Thank you!
http://www.fairchildsemi.com/ds/FQ/FQP50N06.pdf
http://www.irf.com/product-info/datasheets/data/irf1010e.pdf
Thank you!
That is what I had in mind also, but don´t the larger Imput capasitance and Gate Charge on the 1010 cause harm anyway? What I mean is that should the drive for FETs modify also....maybe place mosfet driver IC (MIC4416YM4 TR for example) in place of the power fet driver transistors?
You assumed quite right Reason why I didn´t share specific info about amp is because there is no broken amp with 50N06 FETs inside now. I´ve only been wondering that because I have maybe 100 pieces of that IRF1010 so I would save a long penny if they would fit somewhere.
Most of the korean amps wich are sold here in Finland are Autostudio, SPL Dynamics and Focus and they all burn with low input voltages or low load on SPL competitions..and all of these amps (below ~3kW) use that 50N06 as a power FET.
But the principles of their desing is as you said..PNP..494 etc.
Different FETs, but basically like this.....? (Other side is with old transistor and other with new fet driver.
http://kuvaton.com/k/YN5h.jpg
Am I all lost here?
Am I all lost here?
- General Interest
- Car Audio
- 50N06 replacement with IRF1010??
