Identifying smd diodes on Hifonics 2010d Driver board - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 26th November 2013, 11:19 AM   #1
Default Identifying smd diodes on Hifonics 2010d Driver board
I can't make out the codes on Perry's photo 100% and want to make sure I order the right diodes because I know the ones I have circled in red (D3, D6, D7) in Perry's photo are different than D1 and D2.
Just to be clear im looking for D3, D6, and D7.
My best guess is their marked J2 and the other 2 are A2?
Click the image to open in full size..
Old 26th November 2013, 11:59 AM   #2
nikb47 is offline nikb47  United States
That's what it looks like to me.
Old 26th November 2013, 04:07 PM   #3
http://rohmfs.rohm.com/jp/products/d...udzs6.8b-j.pdf
That's correct. The datasheet above 'MAY' give the correct codes but I've never confirmed that they're the right codes.
Old 27th November 2013, 12:56 AM   #4
Thanks Perry, I don't know if this helps but on a good board there testing .762mv on diode test in and out of circuit. At first I thought they may be the same as d1 and d2 on that board but those are only .550 or so on diode out of circuit. For educational purposes I tried same diode in d3 but it trips the protection circuit in my power supply when the remote lead connection is made.
Old 27th November 2013, 01:59 AM   #5
If you want to confirm that they're zener diodes, connect a relatively high value resistor (1k-4.7k) in series with the diode and connect the two across the 12v power supply. The zener will drop its value. You could compare that to the datasheet.
Old 27th November 2013, 02:08 AM   #6
Awesome, that's what I was looking for thanks!
Old 28th November 2013, 02:03 AM   #7
Confirmed that the two diodes in question match the linked datasheet. 5.06v and 8.27v measured voltage.
Old 8th March 2014, 01:29 PM   #8
For the heck of it, if anyone stumbles upon this I found a good reference for testing zener diodes.
Page65
Hifonics audio driver board seankane Car Audio 32 14th September 2015 12:13 PM
Need help Identifying a few driverboard and pwm board parts (hifonics 2010d, 2006) bl4ckw1d0w Car Audio 14 28th August 2014 03:30 AM
Hifonics 2010D Protect Mode Help. bl4ckw1d0w Car Audio 6 7th October 2013 04:10 PM
Need help! Hifonics Brutus bxi 2010D 2000 Watt Amp! ZarazuaT Car Audio 12 15th January 2013 09:09 PM
Need help! Hifonics Brutus bxi 2010D CurrentDraw (Pulled Driver board still protect) bl4ckw1d0w Car Audio 18 11th September 2012 12:11 PM
Copyright 1999-2017 diyAudio
