Kenwood kac-5201
Kenwood kac-5201
Old 7th November 2013, 11:57 AM   #1
michaeleanor is offline michaeleanor
Default Kenwood kac-5201
Hello Everyone,
I would appreciate if some one helps me in fixing my car amplifier KAC-5201.
While playing it on high volume the amp hot burned, i have changed the power supply fets and the resistor (R91-94), i have attached the schematic .
on powering on it, it still remains in protection mode, i have checked the voltages on IC1,2,3,4 all the readings are correct as per the schematic except in IC 4 at pin 7 I am getting 5volts when the voltage is suppose to be 1.2 volt, can some one advice me which parts should i check to identify the problem.
Old 7th November 2013, 12:03 PM   #2
I can pm the schematic
Old 7th November 2013, 12:17 PM   #3
Perry Babin is offline Perry Babin  United States
IC4 pin 7 is ground and should read 0v.
Old 7th November 2013, 01:08 PM   #4
Hi Perry my mistake I meant ic 3 pin 7 should have 0.1 volt but its giving me 5volts
Old 7th November 2013, 01:12 PM   #5
Post the DC voltage on all pins of that IC. Copy and paste the following list.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Old 7th November 2013, 03:13 PM   #6
with the ic in
Pin 1: -20.20
Pin 2: 0.08
Pin 3: 0
Pin 4: -21.56
Pin 5: 0
Pin 6: 0
Pin 7: -20.30
Pin 8: 21.74
Old 7th November 2013, 03:16 PM   #7
voltage on circuit board after removing the ic
Pin 1: 1.40
Pin 2: -0.80
Pin 3: 0
Pin 4: -22.09
Pin 5: 0
Pin 6: 0
Pin 7: -6.40
Pin 8: 22.14
Old 7th November 2013, 05:31 PM   #8
What is the DC voltage measured directly across the left channel speaker terminals?
Old 7th November 2013, 06:23 PM   #9
All the above readings that I have given is after removing the output transistor from the circuit, will check and post the dc voltage across the left channel speaker terminals.
Thanks Perry for your assistance
Old 7th November 2013, 06:39 PM   #10
Hi Perry the voltage is 0 both right and left channel
Kenwood kac-5201Hide this!Advertise here!
Kenwood KAC 848 mike49504 Car Audio 28 5th January 2012 06:42 PM
Kenwood KAC 829 mike49504 Car Audio 1 21st April 2011 06:45 PM
Kenwood KAC 7202 mike49504 Car Audio 10 25th February 2011 11:05 PM
Kenwood Kac-649s warpedhifi Car Audio 9 8th June 2010 05:43 PM
Kenwood KAC-X301T and KAC-X201T:Do they share the same board? spooney Car Audio 1 25th October 2007 01:08 AM
