JL 300/2
JL 300/2
Old 26th October 2013, 06:13 PM   #1
PapaZBill is offline PapaZBill  United States
PapaZBill's Avatar
Default JL 300/2
I have a question about this amp. The low impedance lamp is lit. The install and speakers are checked out and the amp was swapped with another 300/2 and works fine with existing install and speaker system.The problem is in the amp. I work on amps for a living, but am not familiar with this amp.I appreciate any advice.Is it possible to get service schematics? I do not have the amp on hand and helping a friend fix amp remotely.
Old 26th October 2013, 09:03 PM   #2
Perry Babin is offline Perry Babin  United States
That's generally an indication that the amp has shorted outputs.
It's unlikely that you'll find schematics for the amp.
Old 28th October 2013, 05:28 PM   #3
PapaZBill's Avatar
are you famaliar with this amp and do you know what the output devices are, by any chance?
Old 28th October 2013, 05:42 PM   #4
PapaZBill's Avatar
I find a thread relating to this JL amp and found out the output mosfets are IRF540. I will check with digikey. Question, do you recommend replacing all of the output mosfets or just the shorted ones?
Old 28th October 2013, 06:01 PM   #5
I recommend replacing all of the outputs in the blown channel. I wouldn't replace the others unless there were signs of abuse/overheating of the other transistors.
JL 300/2Hide this!Advertise here!
JL 300/4 help please! qsilvertwo Car Audio 18 19th July 2012 08:14 PM
JL Audio 10w6v2 or Infinity Kappa 100.3se? Audison SRX4 or Jl 300/4? DcMaN Subwoofers 1 17th September 2010 10:28 AM
JL Audio 300/4 PQatPIT Car Audio 5 4th March 2009 02:06 PM
jl audio 300 2 ppia600 Car Audio 2 6th April 2008 03:54 PM
