Hifonics 2010D Protect Mode Help.
Old 25th September 2013, 08:52 AM   #1
bl4ckw1d0w is offline bl4ckw1d0w  United States
Default Hifonics 2010D Protect Mode Help.
I am having a difficult time with this amplifier and can't figure it out. Looking for some guidance on the steps I should take.
The problem: The amplifier is currently in protect mode and I am not hearing the relay engage at all. Does not click once when 12V is applied and the remote lead connection is made. The light comes on green and goes to protect mode 1 second later. Currently at this stage I have the driver board pulled.
The power supply I am using is a Pyramid PS-52KX
Pyramid - PS52KX - 46 Amp Power Supply
A list of what has been accomplished since this amp has been opened:
1. The power supply contains 12 STP75NF75 Mosfets (Designaton Q9-Q20) wich all have been replaced from a batch of the same date code.
http://www.st.com/web/en/resource/te...CD00002771.pdf
(All mosfets were individual checked regardless according to Speaker Load and Amplifier Failure)
2. All 12 of the 47 Ohm gate resistors in the power supply have been replaced (Circuit Board Designation R32-R38 & R42-R48)
3. 2 of the PNP driver transistors in the power section have been replaced with the same date code: A1275 (Q8 and Q8A)
KTA1275_07 pdf, KTA1275_07 description, KTA1275_07 datasheets, KTA1275_07 view ::: ALLDATASHEET :::
4. 2 of the NPN driver transistors in the power section have been replaced with the same date code: 2SC2383 (Q7 and Q7A)
ALLDATASHEET.COM - Datasheet search site for Electronic Components and Semiconductors and other semiconductors.
- Note Original transistors were C3228 ALLDATASHEET.COM - Datasheet search site for Electronic Components and Semiconductors and other semiconductors.
5. The audio section uses IRF640N (Q202-Q204, Q208-Q210, Q214-Q216, & Q220-Q222) and the new ones have been tested and replaced with the same date code.
IRF640N pdf, IRF640N description, IRF640N datasheets, IRF640N view ::: ALLDATASHEET :::
6. All of the 10 ohm and 100k ohm resistors in the audio section have been replaced (R204-R209, R216-R221, R234-R239, & R246-R251)
7. The 2 LM7815, and 1LM7812 voltage regulators have been replaced with matching date codes.
http://www.synthdiy.com/files/2006/LM7812.pdf
8. The LM7912 negative regulator was also replaced.
9. The Driver board in this one has been pulled right now which is located at IC201. It is labled CON1 Driver board 81013 V1.0. This is the common one found in the Hifonics 2006D models as well.
http://www.bcae1.com/temp/bxi2006dau...rboard01bx.jpg
10. Swapped in a known working 2610 PWM 081013 board to see if it was one of those timing smd resistors for the relay i read in another post but no such luck.
11. Swapped in a known working relay: Golden GK-C-1A-12D
12. I have tested the FR105 diodes (D20-D27) they are all showing around .455v
http://www.rectron.com/data_sheets/fr101-107.pdf
This is what I have accomplished so far. I have checked every pad/via for shorts that I have worked on but I should point out that since the amp has been opened, the original problem of the protect light remains as well as not being able to hear the relay engage at all. I also have been referencing the Aq2200 schematic but the audio section is slightly different. Any help or correction is appreciated.
Old 25th September 2013, 12:50 PM   #2
Perry Babin is offline Perry Babin  United States
Did you replace the transistors in the rectangle?
Sometimes the op-amps will cause the amp to go into protect but it's generally those two transistors.
Old 25th September 2013, 03:59 PM   #3
Yes, those have been replaced with the same date code from the same batch and were tested to be good out of circuit.
I do not have the driver board installed right now but from my experience the amp would indicate a green Led power light without the board installed.
Question: Would it make a difference to have the boad installed back into the circuit after initially removing it? Possibly like somewhat of a reset if those transistors were initially the cause?
Old 26th September 2013, 03:59 AM   #4
seankane is offline seankane  United States
seankane's Avatar
So you replaced the op-amps and the transistors shown in the pic on your driver board?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 26th September 2013, 07:03 PM   #5
The op-amps have not been replaced.
Old 28th September 2013, 03:41 AM   #6
seankane's Avatar
I had one that had a defective op-amp, which was causing the protect. I first replaced the 1D transistors in Perry's photo. Not until I replaced the op-amps did it come out of protect. They are probably TL072C, not sure.
Old 7th October 2013, 03:10 PM   #7
I finally found the problem. I found that q285 and q287 which are KSA1220A's had the emitter and collector shorted. This amp took me a while because I am usually use to those pesky driver transistors more commonly shorting out on the driver board.
KSA1220A pdf, KSA1220A description, KSA1220A datasheets, KSA1220A view ::: ALLDATASHEET :::
Hifonics 2010D Protect Mode Help.Hide this!Advertise here!
Need help Identifying a few driverboard and pwm board parts (hifonics 2010d, 2006) bl4ckw1d0w Car Audio 16 10th December 2017 03:23 AM
Zx6400 hifonics strange protect mode rafcio363 Car Audio 13 28th August 2013 08:56 PM
Need help! Hifonics Brutus bxi 2010D 2000 Watt Amp! ZarazuaT Car Audio 12 15th January 2013 08:09 PM
Hifonics Brutus BXI1610 Amp in Protect mode cwelty Car Audio 13 30th October 2012 09:46 PM
Need help! Hifonics Brutus bxi 2010D CurrentDraw (Pulled Driver board still protect) bl4ckw1d0w Car Audio 18 11th September 2012 11:11 AM
