Digital design
Voltages appear to look correct..
Before putting new outputs in the amp check the following..
Check all the inductors/chokes..
They have a green body and the color bands are yellow purple black,, set your meter to diode check and test them they sould read 0.03 on diode check do you get any reading differnt then 0.03 ??
Also you must replace The Driver IC (IR21844S) that goes to the bank were u had a shorted output..
Also post a high res pic of the Audio driverboard again so I can see it and make sure you have all transistors and resistors in the right locations..
Joined 2009
I'm trying to take a good pictures with my camera,(Sony 10.1 mp)
But after many pictures, non will show the value of
The components. Can any one suggest me a good camera
The I can use for this, I don't mind buying it, I need it any way.
Thanks in advance.
Joined 2009
Thanks for all the help.
Here are the pictures
Joined 2009
After replacing all 4 driver ICs and checking all components one by one
I re solder the driver board back to the amp.
Using the scope I'm getting signal on 8 of the 16 transistors gates, the first 4 and the last 4 of every shoulder Have no signal, also the duty cycle looks like 40% ON 50% OFF.
Please see picture.
