SS 500sx repair - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 13th September 2013, 02:37 PM   #1
Smooopz is offline Smooopz  Norway
Default SS 500sx repair
hi.
i recently got hold of one defect 500sx amp. iv'e been doing some research and looked inside, but my troubleshooting skills arent the best.
i've come this far.
1: burned out recistanse R186(need info)
2: burned out Q46(need info)
3: have to replace; U5, U6, D13, D19, Q39-42, and a bunch of ST9714/18 transistors.(need some input on where to buy and are there replacements parts)
the only schematic i have is for the 500, not the sx.
also i cant find the values on R186 and Q46.
all help will be appreciated:-)
best regards
Old 14th September 2013, 02:14 AM   #2
I don't have the SX diagram. The S version...
1: 10 ohm 1 watt
2: MPS8599
3: Farnell if it's available in your area and if no one has a better suggestion.
Old 16th September 2013, 07:51 PM   #3
nice:-)!
Farnell does have a norwegian site. when searching i get no direct matches, thus i'm a little bit unsertain on wich component to choose. i've got one copy of the 500s but the numbers dont match?
Old 16th September 2013, 09:12 PM   #4
Default progress
iv'e come this far.
TIP102
TIP102 - STMICROELECTRONICS - TRANS NPN DARL 100V 8A TO-220 | Farnell Norge
TIP107
TIP107 - STMICROELECTRONICS - TRANS PNP DARL 100V 8A TO-220 | Farnell Norge
U5
LM317T - STMICROELECTRONICS - V REG ADJ +1.2/37V, TO-220-3, | Farnell Norge
U6
LM337T - TEXAS INSTRUMENTS - V REG ADJ -1.2/37V, TO-220-3, | Farnell Norge
D18
FEP16DT - FAIRCHILD SEMICONDUCTOR - DIODE DUAL, 16A, 200V, TO220AB | Farnell Norge
D19
Farnell did not have this in the webshop (FEN16DT) i know Ebay has.
have i got the right values?
The NDP7050(TIP) have a number in addition, they are as follows: 9712(TIP102?) , 9714(TIP107?) and 9718( ?? ). what does these numbers mean?
when i got these parts sorted out im gonna order the FEB pcb's and the replacement switches. then i should be ready to test:-)?
Old 17th September 2013, 03:12 AM   #5
90scaraudio's Avatar
These were turned on to me by 1moreamp...
The NDP7050 MosFets work fine but these have a higher temp rating and I use them all the time...
Compare the two your self...
http://media.digikey.com/pdf/Data%20...Fs/NDP7050.pdf
http://www.fairchildsemi.com/ds/HU/HUF75339P3.pdf
The other parts you listed look correct... I would replace those old electrolytic capacitors, any one in the audio signal path I used audio grade type and I used low ESR type for the rest. On the front end boards I replaced those 22uf/16v caps and on the pre-amp board I replaced those SMD electrolytics...every one I've removed had leaked and also there is another board for the mute and clip function that has SMD electolytics and again every one I've pulled had leaked. Its a lot of work but it sure made these sound excellent again.
Oh and its not fun but you might get lucky getting close enough matched Darlington pairs. To check the bias for each output pair, measure the voltage from emitter pin (TIP102) to emitter pin (TIP107) for that pair. NOT across just one resistor. You want to measure across BOTH emitter resistors. See attached. If you find a pair that is higher than the rest, then measure across each emitter resistor to find the current hog and replace that device. The one with the higher voltage is the current hog. Also, check the emitter resistors too. They can open up on you. I seem to remember about 2 to 2.2 mv across both and about 1 to 1.1 mv across each resister.
Don't forget the NE 5532, TL072 and TL074 opamps....I've put new ones in mine and it straightened out sound issues in some of these. And don't forget the 2SA1562 and the 2N2222 trans in the power supply section. Cant think anymore
Old 17th September 2013, 04:03 AM   #6
One more thing...IMO I try not to replace any of the TIP102, 107 pairs if possible, if they work it seems that they were matched well.
Old 17th September 2013, 10:10 AM   #7
Thanks alot for that! i'll dive into it straight away(after work
Old 17th September 2013, 10:20 AM   #8
Did you get the email???
Old 20th September 2013, 09:29 PM   #9
evianamp2011's Avatar
I believe I have all the parts in stock, (at least all the TO220 components used on that ss). If you can't find it PM or email me.
Tek TDS1002B, Rigol DS1052E, Keithley 2015THD, Fluke 87-V 83-V & 111, DC Clamp meter, APS 90a 13.6v PS, Adjustable 0-30v/0-5a PS.
Old 21st September 2013, 02:47 PM   #10
got the email:-, excellent quality. have ordered the transistor's and now i'm gonna order capacitors and smd's
Soundstream Reference 500sx Repair sdiesel Car Audio 18 16th April 2014 01:17 AM
VOX DEFIANT SS AMP. REPAIR PROFESSOUR2003 Instruments and Amps 14 23rd April 2011 02:33 AM
Need Help to repair my Sony SS-X7 speakers Lee Knatta Multi-Way 13 29th January 2011 03:44 PM
soundstream reference 500sx mike49504 Car Audio 18 2nd January 2010 09:00 AM
Sansui B-2102, huge SS for parts or repair: $75 obo pjanda1 Swap Meet 8 20th September 2008 01:03 AM
Copyright 1999-2017 diyAudio
