driver subs - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 7th September 2013, 03:19 AM   #1
Default driver subs
hi all
Can i used BD140 and BD139 in place of A1220 and C2690?
This is in a hifonics class D amp to drive the output FETs IRF640n
Also can i used them to drive the PS FETs when A1275 is being used as drivers?
Old 7th September 2013, 06:06 AM   #2
They can be used in the supply. In an amp that uses 640s and 9640s, they may work but I think the voltage would be too high for the high-side drive to use the BD transistors.
Did the drivers for the outputs fail?
Old 8th September 2013, 02:56 AM   #3
The drivers did not fail but i wanted to change them.
Old 8th September 2013, 07:48 AM   #4
Order them with your next parts order so you can have them if you need them. The A suffix parts are rated for higher voltage than the non-A suffix versions.
As a side note, I've never seen those driver transistors fail in any of the amps that use them with the small audio driver board.
Multiple-Small-Subs vs A-Few-Large-Subs Eskae Subwoofers 11 21st August 2013 09:17 PM
ma audio hk-4000 ,no sound to subs ?MA AUDIO HK-4000,NO OUTPUT TO SUBS WRENCH030380 Class D 2 8th March 2011 12:38 AM
Dual Driver Subs? bluegti Subwoofers 17 9th October 2006 07:03 PM
Convert floor standers to subs with Tang Band 8" subs? prerunnerv6 Subwoofers 3 26th February 2006 01:44 AM
2 subs one box/2 subs 2 boxes vetkilr Subwoofers 5 22nd February 2006 10:27 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
