can i fix my broken sub
Old 2nd September 2013, 03:46 PM   #1
corie5508 is offline corie5508  United States
Default can i fix my broken sub
I was at a comp and one of my subs stuck in the up position. the glue on the spider failed and the coil came out of the magnetic gap... any thoughts on if the sub is fixable... i ordered some CA glue but not sure if there will be problems with the coil..pole piece ...or top plate
the coil isnt discolored..appears to b fine
any info would b helpful
Old 2nd September 2013, 08:44 PM   #2
Perry Babin is offline Perry Babin  United States
If it's frozen, it's not likely to be repairable without re-coning it. It's likely that some of the windings stuck to the former and the rest broke loose. The manufacturer should be able to repair it.
can i fix my broken subHide this!Advertise here!
Fix broken FE206ES-R? mfaughn Full Range 0 15th September 2010 12:33 AM
How can I fix this? Tenson Everything Else 12 28th August 2008 08:54 PM
Perpetuum-Ebner PE66: To fix or not to fix... Grendel the Cat Everything Else 0 6th April 2007 06:37 AM
