soundstream clone boards
Old 1st September 2013, 07:32 PM   #1
ian33 is offline ian33
Default soundstream clone boards
Hi all
This amp(A3000DB) came in with bad PS FETs and outputs.some track on the board has been mess with .I want to no if this is ok (see pic) also there is a blue wire going to the output terminal should it be there.
Not sure about the modle but i have seen this board in a fifferent amp.
Old 1st September 2013, 08:56 PM   #2
Perry Babin is offline Perry Babin  United States
The blue wire appears to be connecting the secondary ground to the negative speaker terminal. the connection is right but it may cause problems (some amps are sensitive to the routing of grounds). Try to find the break in the original foil and repair the break.
THIS is a photo of an intact board.
Old 4th September 2013, 05:20 AM   #3
Base on the dvd all wave forms on the driver board seem to be ok expect for (-in)
The trace remain straight and gets a little thicker.Did i miss something ?
The wave forms on the first leg on the low and high side FETs are different is that normal?
Amp plays good audio.
soundstream clone boardsHide this!Advertise here!
F5 clone boards (inc PSU boards) Tazzz Swap Meet 39 7th June 2014 08:02 AM
Wanted Gamut Clone PC Boards sdman Swap Meet 0 23rd November 2011 09:38 PM
NP F1 Clone Boards suds Group Buys 41 7th December 2010 11:49 PM
B1 Clone Boards for Sale vdi_nenna Swap Meet 15 15th January 2009 07:14 PM
WTB- soundstream boards! marko Swap Meet 0 30th April 2008 07:36 PM
