Audioque amp problems
Old 29th August 2013, 09:29 PM   #1
Zookz is offline Zookz
Default Audioque amp problems
I have an Audioque 2200.1D V2 amp. It powers on and has the green light with no excessive current draw at all. When I apply RCA's from my tone generator and turn it on and output a signal into the amplifier (with no speakers connected) it will have not only the AC voltage on the speaker terminals, but also have DC voltage. If I turn up the RCA signal and make the amp output around a few volts DC it will go into DC offset protection. If I leave the input signal down and the output on the terminals at around 1Vdc or so it will stay powered on. If I connect a speaker it will hum until you turn it up and it protects. It outputs DC and AC voltage so I'm still getting the audio signal through. All output FET's seem good with no shorts. Any help would be great!
Old 29th August 2013, 09:35 PM   #2
Perry Babin is offline Perry Babin  United States
Q7, 11, 19 and 22 commonly fail. They can fail in several ways (leaky, open, shorted) so you have to either replace them or check them carefully.
I'm assuming that this is the 2610 driver board.
Old 29th August 2013, 10:05 PM   #3
Thanks, Perry. I removed all four of those transistors and checked them and they are each still working. Would you care to share what a replacement part number would be for those for future reference?
Old 29th August 2013, 10:17 PM   #4
The SMD Code Book
1D = MMBTA42
2D = MMBTA92
If you can find no other problems, replace them. Sometimes transistors that are run hot can have intermittent internal connections.
Old 29th August 2013, 10:36 PM   #5
Thanks for the resource! I have MMBTA42's on hand but I do not have any MMBTA92's. I do have some MMBTA56 and MMBTA92LT1. Would either of those be ok to use?
Old 29th August 2013, 10:44 PM   #6
Also, what else should I check or look for? The power supply is perfect and I believe it's on the audio side. I did test the voltage regulators and the 15V regulators are fine but one of the 12V regulators is reading normal and the other has around rail voltage on two of the legs somehow.
Old 29th August 2013, 10:53 PM   #7
These are the only components that I've seen cause the fault you described.
Why won't the MMBTA92s that you have work?
Old 30th August 2013, 12:25 AM   #8
I thought that the ending numbers may make it different. I will replace those and see what happens.
Old 3rd September 2013, 10:37 PM   #9
I just replaced those four transistors on the output driver board and the amp is doing the exact same thing. When I pulled all four transistors they checked good and the new ones did as well. What else could I check?
Old 6th September 2013, 12:24 AM   #10
I decided to take the board out to do further testing and as I was sliding it out of the case I noticed that all four rectifier diodes on the board (FMU32U) had broken legs in the same spot. I'm not 100% sure if this happened when I was sliding the board somehow, or if it was previous. They made a clean break and when I slid the board back over them they were actually making contact barely. Anyways, now that the board is out and I put the diodes back in place I cannot replicate the issue with this amp. It outputs a clean AC signal and no DC now. Could the diodes have caused the amp to still be able to turn on and output an AC signal but also pass DC if one leg wasn't connected or something?
Should I put the amp back in the case and install all of the heatsink clamps again and test it. If it works fine should I consider the amp "fixed"?
Audioque amp problemsHide this!Advertise here!
Autocostuire Fenice 20a & hiss problems Stoatgobbler Class D 29 13th January 2013 01:07 PM
Audioque 1200d? eastman474 Car Audio 2 9th September 2009 11:06 PM
Audioque 1200d? eastman474 Class D 3 29th August 2009 12:40 AM
P3A bias problems & drivers getting hot felix42 Solid State 4 25th April 2007 06:21 AM
"classic" amp and begginners problems (pcb wiring, component values) adi81bv Solid State 15 17th April 2007 09:50 AM
