car stereo
car stereo
Old 26th August 2013, 10:17 PM   #1
manoli337 is offline manoli337  Canada
Exclamation car stereo
hi everybody,
im actually looking about a good car sound system to buy. i got a civic 2002. my speaker size is 6.5" at the front and the rear.I just bought a pioneer DEH-X6500BT.
I would like to know, wich speakers should i buy to get big bass and the more chest compression as possible.
can you help me reaching my goal ?
Old 27th August 2013, 12:38 PM   #2
Perry Babin is offline Perry Babin  United States
You need to provide more information to get useful suggestions.
Budget?
Amount of space you're willing to lose to the enclosure?
Power amp to be used with the woofers?
Old 27th August 2013, 03:56 PM   #3
Is on m'y car so i was just thinking about remplacing the old speakers without an enclosure. Also i CAN plug up to 3 amplifiers with my pioneer stereo. My budget is low, so if you CAN find speakers that make chest compression. And later i Will add an amplifier on them.
Is that possible?
Old 27th August 2013, 04:12 PM   #4
If you want to be able to feel the impact in your chest, you're going to need to move a lot of air. That generally takes large speakers and a lot of power.
You should go to a car audio shop and see if they have any demo vehicles. If so, listen to them and see how much it would cost to get the bass you want.
Old 27th August 2013, 04:45 PM   #5
Okay , but there is no 6.5 " woofer able to move that Much air or CAN almost reach the same impact?
Old 27th August 2013, 04:52 PM   #6
I don't know of any but that doesn't mean that there aren't any. I know that they make 8" woofers that will produce significant bass but they're generally expensive and need significant power to drive them hard.
To get strong bass, it's likely that you're going to need an enclosure.
Maybe someone else will have some suggestions.
Old 27th August 2013, 08:24 PM   #7
neela30 is offline neela30  United States
I bought a cheap subwoofer off of amazon and built the enclosure myself for roughly $30. It's not like anything I used years ago but I am generally surprised at the cost/sound factor.
If your budget is a big concern you could go the route that I did.
Amazon.com: Legacy LWF10X 10'' 400 Watt Legacy ''L'' Series Woofer (Set of 1): Car Electronics
3/4 in.x 2 ft. x 4 ft. Medium Density Fiberboard Handy Panel-1508112 at The Home Depot
You will need access to a table saw if you want to build the box. I used a circular saw that I have but using one will make the job a bit tougher.
I have a 2005 civic myself. I haven't installed a sub in it but may try what I have someday when I get bored.
Old 29th August 2013, 11:02 PM   #8
im talking without a subwoofer or any box or car modifications. like , 2 coaxials at the front and 2 component at the rear. what are the speakers that can get the close to a chest compression...?
Old 29th August 2013, 11:09 PM   #9
It may be difficult get a definitive answer because this is subjective. 'chest compression' for some may mean enough pressure to make it difficult to breathe. If that's what you want, it's not possible with speakers mounted in the door. If you simply want to feel a slight thumping, that may be possible but it would likely require expensive speakers and an amplifier. Even then, the bass produced would likely be midbass, not sub bass.
Old 29th August 2013, 11:17 PM   #10
[QUOTE=Perry Babin;3613227]It may be difficult get a definitive answer because this is subjective. 'chest compression' for some may mean enough pressure to make it difficult to breathe. If that's what you want, it's not possible with speakers mounted in the door. If you simply want to feel a slight thumping, that may be possible but it would likely require expensive speakers and an amplifier. Even then, the bass produced would likely be midbass, not sub bass.[/QUO
what kind of expensive ? and could you share me brands or links?, is there midbass speakers that are hitting lower frequencies like sub ?
car stereoHide this!Advertise here!
Car stereo boombox Adamfbb Construction Tips 2 24th May 2012 04:09 PM
a new car stereo in an old chassis dbc105 Car Audio 3 3rd April 2012 01:40 PM
Suggestions for car stereo? majerjack Car Audio 2 16th December 2010 02:14 AM
Car stereo thepentium Car Audio 1 9th February 2005 12:28 PM
Car Stereo Qeustion Kon Multi-Way 2 27th November 2002 03:58 AM
