Brutus BXI2006
Got a Brutus BXI2006 (Hi Fonics) with blown power supply and shorted outputs.
If in getting 12v and 3.3v at the pads(power supply) do I still need to replace the driver trannies?
If so are these located in Q07 and Q08? there appears to be 2 of each, Im assuming 1 set for each back.
I also noticed this amp uses all IRF640's with no 9640's
From reading the other posts about this amp I can use IRF3205's instead of the DFP units.
I have the BD139's and BD140's still waiting on then outputs, the BD's are a different package type so do you mount them with the numbers facing the same way as the originals? or do i have to turn them around?
Also purchased a BK 2120 scope now i just need a waveform to test.
