need help - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 11th August 2013, 03:56 PM   #1
Question need help
Hi everyone..I'm new to the sight. Hope I am posting in right area. My grandaughter has a 2002 Chevy Impala 3.8 with a Delphi Delco stereo part #10324040. She let someone attempt to install a CD player in car and that didnt work. We want to reinstall the Delco back into the car. Problem is the guy cut wires at back of radio leaving 1/4" of wire! It has 2 plug-ins on back of it. One 24-pin and one 12-pin. We bought new wiring harness for it part#71-2003-1. The original plug-in used 16 wires on 24-pin and 2 wires on 12-pin. The new ones have 24 wires and 8 wires. What I am confused about is that the new one doesn't exactly match the old one. Colored wires don't come out of plug-in at same locations as original. Maybe I just need a wiring diagram for original hookup..Hope someone can help me with this dilemma..Thanks in advance!
Old 11th August 2013, 06:12 PM   #3
Thank you very much..I will check it out!
Old 13th August 2013, 10:58 PM   #4
is the new plugs on the loom the same shape? they fit in the stereo? I wouldn't be surprised if the loom is also for the more advanced head units that have extra wires for additional features that aren't needed on your particularly head unit
Old 14th August 2013, 03:52 AM   #5
Hi, yea the plugs fit the head unit. And I know it only uses 18 wires total..the large plug has 24 wires and the smaller one has 8. I need to use 16 on large side and 2 on small side. I can match some of them up by matching colors and going by a diagram sent with the plugs. Also looked up a Gm diagram for color codes. But I still have several wires I'm not sure about..no colors match. I wish I had a pin-out color coded diagram of the original plugs. I know I could do it then. But have had no luck on finding that yet. But thanks a lot for your help and for your time.
Old 15th August 2013, 06:54 AM   #6
realistically, unless you connect the wrong wires together, NOT connecting a wire should not cause a problem. you may fluke it and it works without them. or they may be for something like a from wire that dims the lights or activities lights when the head lights are on, or some other feature that doesn't have to be there. can't hurt to try.
Old 15th August 2013, 05:20 PM   #7
Hi again..there is one wire that is hot when key on ..It is a gray wire. I think that is the power. Would I connect it to the battery + wire or the ignition 12V+ wire? I am just gonna start trying wires and hope I dont blow the head unit! Thanks for your help.
Old 15th August 2013, 07:28 PM   #8
You need both the batt and the ignition wires connected to the radio properly. There should also be an illumination voltage wire.
Follow the color codes to the letter, not the color, for the car and radio. I found that I had to dig a bit on the internets to get the EXACT colors for my specific model. Definitely do not just match colors without doing so from a chart made from the respective harness info.
Any wires that are unneeded get taped at the ends.
Mike
Old 16th August 2013, 04:14 PM   #9
Yellow is 12v keyed
Orange in 12v battery
DK grey is the dimmer
LT Blue right rear speaker -
DR Blue right rear speaker +
Yellow left rear speker -
Brown left rear speaker +
Lt Green right front speaker +
Dk Green right front speaker -
Tan left front speaker +
Lt grey left front speaker -
Pink power antenna
Blk ground
Copyright 1999-2017 diyAudio
