MTX Thunder 5601
MTX Thunder 5601
Old 31st August 2013, 07:42 PM   #41
Perry Babin is offline Perry Babin  United States
Did you read posts #38 and 39?
Old 31st August 2013, 07:46 PM   #42
S Merlington is offline S Merlington  United States
R203 On the Preamp board appears to have over heated didnt catch that at first..
Do you happen to know he value of that??
Also R204 seems to have overheated as well
Old 31st August 2013, 08:02 PM   #43
Ok im guessing theese resistors are all 10 ohm resistors..
R203 goes to pin 4 of the TL074C
R204 goes to Pin 11 of the TLO74C
R118 goes to Pin 4 of another TL074C
R117 goes to Pin 11 of the TL074C
Wow i over looked alot of stuff..
If theese are 10 ohm resistors every one of them is defective going to every op-amp on the preamp board
Old 31st August 2013, 08:06 PM   #44
Board number MVP183?
R203 appears to be a 0 ohm jumper. R204 is a 10 ohm resistor.
Old 31st August 2013, 08:08 PM   #45
R117 and R118 are 10 ohms.
Old 31st August 2013, 08:46 PM   #46
The Preamp board Number is MVP184-B
On this board R203 appears to be a 10ohm
So far i found the following resistors bad
R203,R204,R111,R112,R117,R118,
Which appear to all be 10 ohm resistors..
Ill have to put this amp aside til tuesday until i can get to the stire and get some 10 ohm resistors..'
Do you think any of the op-amps may be defective??
Wondering if i should pick some op-amps up as well ??
Old 31st August 2013, 08:53 PM   #47
This is the same board as the 7801. I was looking at the 4501 board.
R203 is 10 ohms.
The op-amps do sometimes fail. It's just like the op-amps on the main board. The series resistors sometimes protect the op-amps but not always.
Old 4th September 2013, 03:47 AM   #48
Back to this amp..
I replaced all 10 ohm resistors on the preamp board..
When i power it up the amp will draw 10 amps of current and no lights on the preamp board light up..
After i remove power from the amp the lights on the preamp board light up for a sec..
I noticed R122,R112 R121,R203 burnt up within 2 secs..
Does this mean the op-amps could be defective or what do i need to check next?
Old 5th September 2013, 04:20 AM   #49
Randy62 is offline Randy62  United States
If those resistors are in series with the +/-15 and the op-amps you need to replace them.I usually always have to replace all the op-amps on these MTX amps when the voltage regulators short.
Old 6th September 2013, 01:01 AM   #50
#48 was answered in post #39.
MTX Thunder 5601Hide this!Advertise here!
mtx thunder 5601 bass monkey Car Audio 9 28th May 2012 12:43 AM
MTX Thunder 5601 mike49504 Car Audio 3 15th April 2012 01:27 AM
MTX Thunder 5601 burnt CobraTom Car Audio 5 19th January 2012 11:21 AM
MTX 5601 Amp Help Please Kmazzeo26 Car Audio 3 2nd June 2010 08:51 PM
Any help with MTX 5601 amp? Jorel Car Audio 1 31st March 2010 06:35 PM
