MTX Thunder 5601
MTX Thunder 5601
Old 29th August 2013, 08:28 PM   #11
Perry Babin is offline Perry Babin  United States
I wouldn't replace the TL072 without a reason.
The failure of the voltage regulators can cause extensive damage. There is likely damage on the preamp board as well.
When you power it up, make sure all components are clamped. Do not connect the preamp board until you know that the regulators are OK.
With the scope set to 5v/div, place your scope probe on the regulator output leg and power the amp up. If the voltage viewed on the scope goes off of the display, immediately shut down the amp to prevent further damage. Do for both the positive and negative regulators.
Old 30th August 2013, 04:02 AM   #12
S Merlington is offline S Merlington  United States
Well Replaced R143, R406,
Im guessing the rail caps are defective also I removed them from the board and can hear the inners rattling around in the cap
Old 30th August 2013, 05:17 AM   #13
Set scope to 5v div..
And 5us or 5ms ?
Also your talking about the Mur1620ctr and the byw51 ?
Old 30th August 2013, 06:14 AM   #14
The two IRF540s near the rectifiers are the regulators. You can check on the ends of R318 and R319 farthest from the IC.
Old 30th August 2013, 07:06 AM   #15
The trace on the scope stays centerd
Set the scope to 5v div and 5 ms tryed a couple different posistions and it stayed centerd
Old 30th August 2013, 09:51 AM   #16
Did you confirm that the power supply was operating?
Old 30th August 2013, 02:28 PM   #17
I have a nice square wave on the power supply fets (gate leg)
Im getting + - 15 volts of regulated voltage
Im getting -63 and + 56 volts of rail..
But im getting 56.2 volts measured directly across the outputs..
Any idea what might cause this?
Old 30th August 2013, 04:20 PM   #18
Post the DC voltage on all pins of the op-amp between R405 and R407.
Old 30th August 2013, 06:59 PM   #19
NE5532
Pin 1:12.59
Pin 2:13.60
Pin 3:13.81
Pin 4:-15.34
Pin 5:13.72
Pin 6:13.99
Pin 7:14.59
Pin 8:15.46
Old 30th August 2013, 07:38 PM   #20
It appears to be defective but since the input voltages are so near the supply voltage, it's not possible to tell definitively.
MTX Thunder 5601Hide this!Advertise here!
mtx thunder 5601 bass monkey Car Audio 9 28th May 2012 12:43 AM
MTX Thunder 5601 mike49504 Car Audio 3 15th April 2012 01:27 AM
MTX Thunder 5601 burnt CobraTom Car Audio 5 19th January 2012 11:21 AM
MTX 5601 Amp Help Please Kmazzeo26 Car Audio 3 2nd June 2010 08:51 PM
Any help with MTX 5601 amp? Jorel Car Audio 1 31st March 2010 06:35 PM
