Faulty MTX 500D
Faulty MTX 500D
Old 2nd September 2013, 09:31 PM   #21
Chuppster is offline Chuppster  United States
HUF75339P3 Fairchild Semiconductor | Mouser
Will these be a sufficient replacement for FET201-204?
Old 2nd September 2013, 10:06 PM   #22
Perry Babin is offline Perry Babin  United States
Those will work.
Old 17th October 2013, 05:39 PM   #23
I replaced the resistors with 390 ohm and replaced FET201-204. Replacing the resistors was interesting - some of the leads were rather burnt and had seprated from the board, but I think everything is okay now, there seems to be a connection where there needs to be. No power, though. Now should I go for the components over the blackened area of the board, such as Q691-Q65?
Old 18th November 2013, 05:45 PM   #24
I have replaced the power supply transistors as well as the blown out resistors. No LED, but the power supply transistors get plenty warm. Next, should I replace these?
http://www.bcae1.com/temp/mtx500dregulatordamage01.swf
Does anybody have the schematics for this amp?
Old 18th November 2013, 07:26 PM   #25
If you pull the rectifiers, does the power supply function without the FETs overheating?
Old 18th November 2013, 09:12 PM   #26
I pulled the 2 rectifiers, still no LED. The power supply transistors don't' heat up, though.
Old 19th November 2013, 11:59 AM   #27
Is the area around the regulators discolored?
Have you checked the output transistors to confirm that they're not shorted?
Old 19th November 2013, 08:19 PM   #28
I'm getting about 28 megaohms between pins 1-3 both ways on each of them. Defiantly not shorted. These are SSP45N20A, FET 101-104. The only discoloration on the board centers around those resistors I replaced.
Old 19th November 2013, 08:25 PM   #29
What about 1-2 and 2-3?
Old 19th November 2013, 08:48 PM   #30
There are no shorts, regardless of polarity.
I seem to have mixed up my rectifiers. What are the model numbers for REC201 and REC202?
Faulty MTX 500DHide this!Advertise here!
MTX 500D jomede Car Audio 6 14th February 2012 07:10 PM
What do I do with this faulty mtx 500d? odinsragess Car Audio 3 10th October 2009 11:49 AM
Help me fix MTX 152 and MTX 500D hakentt Car Audio 94 8th December 2008 06:26 PM
MTX 500D help audiobahnkid592 Car Audio 28 15th July 2008 11:43 AM
Another dead MTX 500D dpaton Car Audio 1 22nd September 2007 07:53 PM
