Faulty MTX 500D
Faulty MTX 500D
Old 20th August 2013, 02:15 AM   #11
Perry Babin is offline Perry Babin  United States
The increase in value won't cause the amp to produce less power. There is a thread where it shows the resistors under the board and against the heatsink.
Old 2nd September 2013, 04:38 PM   #12
Chuppster is offline Chuppster  United States
Okay, I finally got my multimeter back, and now I can resume work. REC201 and REC202 have 2 different kinds of transistors. Are they supposed to be the same?
Old 2nd September 2013, 08:39 PM   #13
Those aren't transistors. They're rectifiers. One is the positive rectifier. The other is the negative rectifier.
Old 2nd September 2013, 08:52 PM   #14
I see. If I'm testing these correctly, they seem to be okay. It only shorts 1 way, and that way is opposite between each side of the center pin. There is no apparent damage. Should I order parts anyway?
Old 2nd September 2013, 08:58 PM   #15
Rectifiers (in the board) generally read shorted between legs 1 and 3. They should not read as shorted any other way.
Old 2nd September 2013, 09:13 PM   #16
These rectifiers read a short between 1 and 3, then they short when and only when neg=1 pos=2 and pos=2 neg=3.
Old 2nd September 2013, 09:25 PM   #17
Shorted is 0 ohms. Are you saying that the meter reads 0 ohms 1 way and not the other (lead placement)?
If so, your meter is likely giving you false readings.
Old 2nd September 2013, 09:28 PM   #18
The meter is in diode mode, which, if i'm not mistaken, means it acts as a continuity tester. The multimeter could be giving false readings, it is a joke. I'm ordering an new one.
Old 2nd September 2013, 09:52 PM   #19
You may not need to buy a new one. If you do buy a new one, buy a Fluke (preferably a model 10, 11 or 12).
If you pull the rectifiers, they should read as OK.
'Continuity' can mean a lot of different things.
Old 2nd September 2013, 09:53 PM   #20
Haha, I see. Alright, I'll leave them in.
Faulty MTX 500DHide this!Advertise here!
MTX 500D jomede Car Audio 6 14th February 2012 08:10 PM
What do I do with this faulty mtx 500d? odinsragess Car Audio 3 10th October 2009 12:49 PM
Help me fix MTX 152 and MTX 500D hakentt Car Audio 94 8th December 2008 07:26 PM
MTX 500D help audiobahnkid592 Car Audio 28 15th July 2008 12:43 PM
Another dead MTX 500D dpaton Car Audio 1 22nd September 2007 08:53 PM
Copyright ©1999-2017 diyAudio
