Dead Kicker ZX650.4 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 25th July 2013, 12:04 AM   #1
Default Dead Kicker ZX650.4
Hi there - I am new to this forum and really hoping I can get some assistance here.
I have a Kicker ZX650.4 that doesn't power on. There is nothing visually wrong with the components on the board and the amp itself was only used for about a week (at moderate volumes) before it failed.
I've taken it apart, and with guidance from Perry's car audio repair tutorial I've learned a great deal about amplifiers and poked around some of the components.
I have a soldering iron, basic tools, and a Fluke 117 multimeter.
I believe either the TL494 or the emitter follower BJTs are defective. I don't think the output voltage from the driver IC is high enough to turn on the FETs. Without further ado:
TL494:
1: 1.072
2: 3.127
3: 0.062
4: 0.001
5: 1.511
6: 3.419
7: 0.001
8: 2.163
9: 0.701
10: 0.701
11: 2.162
12: 12.97
13: 5.009
14: 5.009
15: 5.009
16: 4.047
From looking at the board, it appears that the two emitter follower pairs are being driven from pins 9 and 10. However, surely the voltage there should read higher? I'm not sure what the function of pins 8 and 11 is in this particular amplifier, but I believe these should be higher too.
All of the voltages on the gates of the power FETs are equal: 0.568. None are shorted. If this was an issue with one of the emitter follower BJTs, I'd see different gate voltages on from one bank of FETs to another, right?
Please let me know what else I should check. I am not averse to desoldering components, but would prefer to start with simpler tests. Thanks in advance
Old 26th July 2013, 12:07 AM   #2
RiLoWa is offline RiLoWa  United States
RiLoWa's Avatar
The low voltage on pins 8 & 11 is not allowing the 494 to turn on and function causing the low output you measure on pins 9 & 10.
You need to find out why there isn't ~12V there by working back from those pins to find the defective component.
Tools - 1. TPI Scope Plus 440 2. B&K 2125 20MHz Dual Trace 3. Sorensen DCR20-50B 4. B&K 4011 5MHz Function Generator 5. Weller WESD51 6. A big hammer
Old 26th July 2013, 02:34 AM   #3
Indeed! The problem was a blown PNP BJT in position Q6. Had slight visible burn mark that became visible upon closer inspection. It fused open.
Thanks for the help!
Dead Dead Laser Pickups - why not replacing the Diode only? Salar Digital Source 36 14th March 2017 05:21 AM
Need Help with another Kicker 04kx1200.1 Jatruh Car Audio 38 10th July 2012 02:45 AM
Kicker KX350.2 Dead impactair Car Audio 15 2nd February 2012 03:11 AM
kicker xs100 timwebb Car Audio 97 13th October 2011 01:56 AM
Kicker ZR240 kyle0826 Car Audio 2 19th February 2010 02:26 AM
Copyright 1999-2017 diyAudio
