12v, 4 Channel Amplifier for Car PC
Old 9th June 2013, 05:56 AM   #1
juzztf is offline juzztf
Default 12v, 4 Channel Amplifier for Car PC
Hello all,
I am in the market for an amplifier for a car based set-up.
Im attempting to build an all in one Android based car pc with 3G and etc.
The issue I have currently is a gap where the amp should be due to not being able to find something suitable. Which is where I turn to you guys.
To break it down:
The power comes straight from the battery, but is switched by the ignition supply though the ISO connectors. The system only powers up when the ignition is on. From that, I have 4 power connections, 2 x 12v outputs, for the preamps and amplifier, routed off before a 5v 5A regulator for the motherboard and a 5V case fan.
The motherboard itself has 2 stereo jack outputs which I have used to low noise stereo preamps to give them a little kick before they are properly amplified.
This is where the problem is. I need a 12v powered (ideally), 4 channel amp which has a reasonable wattage per channel which will give the at least same volume output that a stock head unit might give, if not better. The speakers themselves have a 90w (5 inch) and 180w (6inch) threshold, but Im sure thats not an issue. All 4 speakers are 4Ω.
Can anyone advise me further on the situation and any advice on what I should get? I'd like the amp to be as small as possible, 100x60mm or less.
Thanks in Advance
JuzzTF
Old 9th June 2013, 06:56 AM   #2
Mihkus is offline Mihkus  Estonia
Mihkus's Avatar
TDA7850 sounded fairly good...
4 Bridge amps no output caps low input resistance, pretty high efficiency...
very few external components tho.
Old 9th June 2013, 08:42 AM   #3
Are there any in particular you would recommend? I have seen a few of the TDA7850 Amps but all seemed like Chinese copies that were not of particularly good quality.
12v, 4 Channel Amplifier for Car PCHide this!Advertise here!
12v 4 Channel Amp, Ideally for a car. juzztf Chip Amps 3 11th June 2013 06:24 AM
class A amplifier on 12V car rails muddasirwaheedmalik Solid State 5 26th July 2012 09:50 PM
12V Car Amplifier.. deepanger Solid State 24 14th February 2011 09:50 PM
Best TDA Chip For 12V Car Audio Amplifier livenicely Chip Amps 7 1st December 2010 04:26 PM
6 channel TA2020 finished amplifier PCB (setup for 12V) maurycy Swap Meet 2 27th February 2009 05:07 PM
