Ampire Class D monoblock troublehooting - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 26th May 2013, 06:00 PM   #1
Mote is offline Mote  Estonia
Default Ampire Class D monoblock troublehooting
I bought this amplifier as broken. It powers up, does not draw current and does not go into protect. Relay clicks but there is no audio. All outputs and PS FETs seem to be fine. Rail voltages (+56V and -56V) are present on output transistors.
I suspect that the driver for outputs has failed but what that chip is I do not know. Numbers have been filed off. Next to it there is op amp which has voltages near rail voltage on every pin. Maybe its missing ground or it is blown? There is no rail to rail oscillation on outputs. Picture added of what I found on outputs.
Anyone know what the driver chip is? Any advice on troubleshooting?
BTW, where is Perry?
Tools: Perrys tutorial, C1-76 o-scope, Weller WHS40, Mastech MAS830L multimeter, Mastech MY6243 LC meter, 16A supply
Old 26th May 2013, 07:43 PM   #2
timwebb is offline timwebb  United States
what amp is this?
Old 26th May 2013, 10:05 PM   #3
evianamp2011's Avatar
U101 appears to be cracked....can you check it to see if it is or just the picture?
Old 27th May 2013, 02:54 AM   #4
Im guessing from the pics That the Driver IC appears to be an IR2010
Old 27th May 2013, 01:42 PM   #5
Amp is Ampire MB 1000.1
I believe that there is some goo on the U101 which makes it seem to be cracked. Will check it.
IR2010 seems to be right. 1st and 8th leg connected to outputs. That is what I have.
Thanks.
Old 10th July 2013, 05:06 PM   #6
Replaced U101, U102 and U103 still now audio, now I get a loud bump from speaker when amp is shutting down.
Outputs are not shorted, power supply is working properly, amp does not draw excessive current.
Any advice?
Old 11th July 2013, 12:44 AM   #7
got pics of the preamp and output section?
RODEK r 1900 N D class monoblock kozik666 Class D 1 7th October 2014 01:05 PM
FS: AV123 X-amp class-D monoblock 150W power amp (CA,USA) CharlieLaub Swap Meet 0 24th April 2013 03:07 PM
Pure Reference Class A Monoblock tiefbassuebertr Solid State 16 5th January 2012 07:47 PM
Want to build a Class D monoblock Car amp gexamb Class D 16 1st September 2009 07:42 PM
Class-A Monoblock Amplifier Chassis (qty 2) tstrafford Swap Meet 8 14th February 2009 05:19 PM
Copyright 1999-2017 diyAudio
