ZX750.1 up in flames. - Page 6 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 7th August 2013, 10:59 PM   #51
Ok I went over the board with a magnified lamp and the only thing I found was a possible bad connection on a blue rectangle close to 4 capacitors marked 105K100, I resoldered it, should I put the rectifiers back in and try it or should I wait. My dad mentioned my grandfather had an old scope in the basement would that possibly work? Im not sure how old it may be.
Old 7th August 2013, 11:55 PM   #52
Post a photo of the component that had the bad solder connections.
Old scopes are OK as long as they have a triggered sweep. What make/model is it?
Old 8th August 2013, 12:14 AM   #53
Default amp pic
Ok heres a pic of the component. Its the little blue rectangle.
As far as the scope goes Ill try to get more info.
Old 8th August 2013, 06:43 PM   #54
The scope I have access to is an old tube type scope so Im not sure it will be what I need. What would the scope allow us to do?
Would this type of scope allow us to do what I need? Ebay item 271252997929, its a Tektronix 475.
Old 8th August 2013, 07:41 PM   #55
Post a photo of the front panel of the scope you have after confirming that it works.
That scope would do everything that you'd need for most all repairs. Do a completed item search to see what they sell for. I'd expect it to sell for over $200.
As a side note, that's a TAS475. It's much different than the older 475.
Old 8th August 2013, 10:43 PM   #56
Ok heres a pic of the ole Jackson scope. This thing is older than me i do believe.
Im gonna place a bid on the TAS475 but it sells for around 300-400 so i dont believe my bid will be enough but ill try.
Old 8th August 2013, 11:34 PM   #57
I doubt that that would be usable.
Reinstall the rectifiers and remove all of the output transistors. After removing the outputs, make sure that there are no solder bridges between any of the pads.
Will it power up without the power supply FETs heating up?
Old 9th August 2013, 04:06 AM   #58
Ok I installed the rectifiers and removed the outputs and lo and behold 2 shorted outputs, How did I miss that? Is it because I checked them in circuit? or did I make a rookie mistake?
I lost the bid on the scope, Im still on the hunt, is there anything specific I should be looking in for a scope?
Old 9th August 2013, 04:27 AM   #59
Did you check them properly? If you don't discharge the gate/source, they may appear shorted. The following page has a section for testing FETs:
Basic Amplifier Repair - Transistor Test Applet Link
A simple analog scope is all you need. Either post auction numbers or email me directly. The used BK Precision 2120B scopes go for about $150 and at that price, they're a good deal.
Old 9th August 2013, 07:47 PM   #60
All three pins of one irf9640 and one irf640 and a dead short. Boards all cleaned up ready to go. Now on to the KX2500 with the same problem.
Ill purchase a scope when payday comes, I plan on repairing more amps, I figure after repairing a few that I should start progressing in the troubleshooting department.
Need schematic for kicker zx750.1 no1stunna Car Audio 19 11th January 2012 04:10 PM
Need help with zx750.1 with no sound kylelemay1 Class D 3 11th May 2011 11:34 PM
Kicker zx750.1 texasrebel1 Car Audio 2 10th January 2009 04:46 PM
Kicker zx750.1 solobaric 10's texasrebel1 Car Audio 2 5th December 2008 01:27 AM
I'm going down in flames amc32 Car Audio 13 11th July 2008 04:18 PM
Copyright 1999-2017 diyAudio
