Soundigital 16kd - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 8th May 2013, 03:31 AM   #1
Default Soundigital 16kd
This unit had 4 bad audio output MOSFET,
They were all replaced together with the IR2113 driver IC,
But know the amp have a noise like if it was missing a ground,
There is audio, but it sound like when an amp have the ground
Shield connector broken.
fluke 50 mhz scope,35 amp power supply,0.5-12v adj power supply, fluke 179,hot air desolder gun, merit multyfuntion signal tracer/generator.
Old 8th May 2013, 10:33 AM   #2
ultra's Avatar
Please, post some pics of the amp
Old 9th May 2013, 01:35 AM   #3
here are some pictures
Old 9th May 2013, 07:56 AM   #4
ultra's Avatar
Do you have +/- 15V on pins 4 and 11 of TL074 ?
Old 9th May 2013, 08:02 PM   #5
There is +/- 12 volts at pins
Old 9th May 2013, 08:29 PM   #6
ultra's Avatar
Looking at your other post, regarding noise, are you sure your signal source is grounded along with your power supply ?
Old 9th May 2013, 11:49 PM   #7
I traced the RCA ground connector and it does not connected straight to the power supply ground, it goes to a couple of resistor and then goes to one of the two tl074 ICs.
Old 10th May 2013, 02:04 PM   #8
ultra's Avatar
what if you connect a cable between the RCA shields of the amp and the ground of your power supply?
Does the noise go away?
Old 11th May 2013, 05:40 PM   #9
Can that cause damage to the amp?
If not I can try it.
Old 11th May 2013, 05:57 PM   #10
ultra's Avatar
No, it will not.
If an amplifier is installed in a car, the RCAs ground is the chassis, so is the power ground of the amp.
How do you feed signal to the amp in your bench?
Soundigital 16kd rodd1two Car Audio 6 19th February 2012 03:54 PM
Copyright 1999-2017 diyAudio
