Rockford Fosgate Punch 150hd Amp
Old 20th April 2013, 12:15 AM   #11
seankane is offline seankane  United States
seankane's Avatar
"200 ohm axial resistor from pin 15 to pin 8 of the TLO72"
Pin 15 is the positive 15v regulated voltage and pin 13 is the negative 15v regulated voltage.
Pin 8 of the TL072C is the negative supply pin for the op-amp. I don't think hooking the positive regulated supply to the negative supply pin of the op-amp would be a good idea.
Do you have the schematic for the input board?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 20th April 2013, 12:32 AM   #12
rickcl is offline rickcl  United States
What I actually need to do is go from pin 13 through the 200 ohm resistor to pin 8 of U2A. Also install C2. Yes I have it (schematic) now.
Old 20th April 2013, 12:41 AM   #13
seankane's Avatar
Correct.
Old 15th November 2013, 04:11 PM   #14
Scotaidh is offline Scotaidh  United States
Hi Guys,
Sorry for bumping an old thread, but I have one of these that looks like the same issue, leaking caps. There is some damage that I thought was heat, but now after reading your posts I'm wondering if it might just be the caps. I think the real problem is the burned trace, just starting on it today.
Old 15th November 2013, 04:18 PM   #15
Perry Babin is offline Perry Babin  United States
Please start a new thread if you have further questions or need help.
Old 12th August 2015, 06:50 PM   #16
Romzilla234 is offline Romzilla234
I have a question. I'm a newbe. I just bought this amp and the one channel wasn't working very well so I tried to open the amp and see why. Well I ended up taking the bigger screws out on the sides and one of the screws broke off well now when I try to hook up positive on amp it blows fuse imediately. Any suggestions as to why and is it a easy fix. I think the screw posed the heatsink away just a tad???
Old 12th August 2015, 07:41 PM   #17
Please don't post in a repair thread that was started by someone else unless you are trying to offer assistance to the original poster.
Click on the red triangle in the lower left corner of your post and ask a moderator to move your post (and any replies to it) to a new thread (my post should be deleted).
After it's moved, I'll try to help you.
Old 9th December 2015, 01:08 AM   #18
Losgorniacos is offline Losgorniacos
Default Punch 150hd schematic
Originally Posted by rickcl View Post
Seankane I don't mean to takeover this thread but what would you do with this board? Possibly a 200 ohm axial resistor from pin 15 to pin 8 of the TLO72 and 10uf from pin 8 to ground?
Hi how can I find the schematic diagram and or service manual for this amp or maybe this input board. Thanks
Old 9th December 2015, 04:27 AM   #19
seankane's Avatar
Honestly I would call Jason at Freemans car stereo. He will sell you a brand new board, I think they are around $30 shipped, not sure. He has many in stock.
You will be time and money ahead to install a new board.
Rockford Fosgate Punch 150hd AmpHide this!Advertise here!
Rockford fosgate punch 150 (1st gen) OP amp #? chipper Car Audio 2 27th May 2018 03:40 AM
Rockford Fosgate Punch 500S seankane Car Audio 39 15th July 2011 05:29 AM
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 04:20 PM
Rockford Fosgate Punch sub question audiomachines Subwoofers 4 18th August 2006 01:51 AM
Rockford Fosgate Punch 360a2 dawkins Car Audio 1 6th April 2006 05:27 PM
