Hifonix BRZ1200.1D issue
This one has a weird issue that I cant pin down.
It works, but it has really low volume. I have to turn the gain all the way up before it begins to beat the subs. Then when I do this, it starts clipping only at certain frequencies, and when this occures it starts cooking the sub, B+ rails drop during clipping.
Idle no clipping I have +/-65V rails. they sag to about 30v when clipping. And its burning the sub when it clips.
Quick measurements gave me this:
100Hz Sinewave tone into RCAs. 0.4VAC input on RCAs.
R201 couples the pre-amp/crossover stage to the Class D driver board. the Driver board side with gain turned all the way up is 0.8VAC.
Pre-amp side of resistor is about 6.5VAC. Resistor measures fine.
is this normal? or is the class D driver bad. Both 8 pin SOIC-W ICs are scratched off. Both get really hot.
any ideas?
See attached.
