Kenwood KAC-9104D output drivers?
Old 19th March 2013, 05:00 PM   #1
Deadly Sones is offline Deadly Sones  Canada
Deadly Sones's Avatar
Default Kenwood KAC-9104D output drivers?
I have a 9104D here with blown low side output transistors so I figure I'll replace both high and low sides.
What are the 2 driver transistors for the high and low side output transistors? Q112 and Q107? I can't get anything to show even using heatsink compound. Also R197 should be 47Kohm SMD(source resistor), just like R188 correct?
It also seems to have lifted and broken the trace that connects the ground of the transformer to the jumper for the ground terminal. Should I just install a jumper wire connecting the transformer directly to the jumper?
If anyone has a schematic for this amp they would like to share with me it would be greatly appreciated.
thx as always!
Old 19th March 2013, 05:04 PM   #2
Perry Babin is offline Perry Babin  United States
Check your email.
Old 19th March 2013, 05:05 PM   #3
Thank you sir!
Kenwood KAC-9104D output drivers?Hide this!Advertise here!
Kenwood Kac-7202...Low distorted output. jordan_ciaramit Car Audio 1 12th August 2012 07:54 AM
Kenwood KAC-X811D, Low power output TheFox84 Car Audio 21 2nd August 2012 12:33 PM
Kenwood 9104D mike49504 Car Audio 7 9th November 2010 11:27 PM
question about transistors in kenwood kac-9104d usmcgrunt0331 Car Audio 50 20th September 2010 09:04 PM
need help identifying a part on kac-9104d usmcgrunt0331 Class D 1 17th September 2010 03:24 AM
