Are you measuring the DC directly across the speaker terminals?
yes
Do you have rail-rail oscillation on the output transistors?
i just checked and there is no oscillation.
i read 28vdc on the inductors.Do the relays engage?
yes
Does the amp draw excessive current when you connect a load to the speaker terminals?
no.
If it doesn't and the voltage drops to 0v across the terminals, do you also read 0v on the output filter inductors?
- General Interest
- Car Audio
- saz3k question
