Crunch GTX3000D
Crunch GTX3000D
Old 20th March 2013, 08:19 AM   #11
Perry Babin is offline Perry Babin  United States
The collectors of the transistors are connected to ground under the tabs of the transistors. The center leg is connected to ground through the transistor.
Old 21st March 2013, 06:48 PM   #12
KriszXJR is offline KriszXJR  Hungary
I replace Fets (to IRF1010E) and BE (to 2sb1123t) transistors, but the ps not start.
The total current ~200mA
(supply voltage 12,5V)
All Fet voltage in G leg is 0V, D: 12,5V, S: 0V
Driver board voltages:
1: 0,79V JRX
2: 90mV Comp
3: 90mV U1_3
4: 12,5V
5: 11,8V
6: 0V GND
7: 12,5V
8: 4,45V E2
9: 4,45V E1
10: 3,65V TH
11. 0V Prot
And relay clicking, but power and protect led no light.
Old 21st March 2013, 06:53 PM   #13
And i replace in driver board two T4 diode to LL4148....
Old 21st March 2013, 08:48 PM   #14
Are E1 and E2 directly connected to the emitters of the two BE transistors?
If so, they should go to the gate resistors for the power supply FETs.
Old 21st March 2013, 10:18 PM   #15
Yes!
On amp pcb - before driver board - have c3198 (Q7) and a1266 (Q6). ???
Old 21st March 2013, 11:42 PM   #16
Post a photo showing Q6/7.
Old 22nd March 2013, 06:43 AM   #17
I signed.
Old 22nd March 2013, 09:13 AM   #18
Have you Perry schematics from this amp, or MB Quart DSC1500.1 ? (MB Quart DSC same as Crunch GTX)
Old 22nd March 2013, 11:54 AM   #19
I don't have any schematics that are the same as this amp.
Do have 12v on the collector of the NPN driver transistor on the main board?
Old 22nd March 2013, 08:29 PM   #20
I measured the voltages. Signed in photo. Thanks!!!
Crunch GTX3000DHide this!Advertise here!
Crunch GP3000 mike49504 Car Audio 52 23rd February 2011 05:14 PM
Crunch GP3000 mike49504 Car Audio 16 26th October 2010 04:15 AM
The crunch meanman64 Car Audio 3 6th March 2006 04:18 AM
Crunch Amps. Radik Multi-Way 0 13th March 2004 01:29 AM
