Rockford Fosgate T30001bd
Old 19th March 2013, 10:26 PM   #41
MatthewS is offline MatthewS  United States
Send a message via AIM to MatthewS Send a message via MSN to MatthewS Send a message via Yahoo to MatthewS
Just now? Yesterday? In 2009? I'm trying to follow but you never mentioned anything about it after post #16 IIRC. Can you bring us up to speed on what/where you've found that has not been posted?
Old 19th March 2013, 10:34 PM   #42
ultra is offline ultra
ultra's Avatar
you are right, sorry i completely forgot about it.
I have found the break since #20.
It was very close to a pad, really difficult to see it.
Old 19th March 2013, 10:40 PM   #43
Ok, can you identify the frequency the hum is on? Hz/Khz.
Old 19th March 2013, 10:42 PM   #44
Perry Babin is offline Perry Babin  United States
You need to repair the -6v regulator.
Old 19th March 2013, 10:56 PM   #45
Posts 9, 16 & 20 suggest he has -6.. albeit a bit low @ -5.88. In post 36 is was too high over -8 volts. This is tough for me to follow because things are being done between posts and we're just not in the loop. Nice catch Perry.
Old 20th March 2013, 02:46 AM   #46
ultra's Avatar
the internet connection where i work is down so i have to go up two flights of stairs to post and i cannot remember everything.
After some examination of the auxiliary voltages, (Perry was right) i managed to get things a bit straight.
I noticed that whenever i touched R312 the noise went away for a second and after re-soldering R312 much of the noise was gone.
I can -sometimes- completely eliminate the noise for just a sec if i turn up and down the gain pot. But it always comes back again.
Now, the high frequency noise is still present, but at least the amp produces audio at the output with signal fed to the RCAs. However, it sounds distorted.
Here is what i mean (amp if fed with 100Hz sine)
Pic 1 the signal between C355 and R300
pic 2 pin 1 of U300
pic 3 the output of the amp at low volume
pic 4 the output of the amp at a bit higher volume....
thats why it sounds distorted
Old 20th March 2013, 02:58 AM   #47
For op-amps 300, 301 and 302, do you read anything more than about 0.01v DC if you place the meter probes on pins 3/4 or 5/6?
Is there any DC offset when you do not inject signal?
Old 20th March 2013, 03:52 AM   #48
ultra's Avatar
All the above op-amps have -6V at pins 4 and 6V at pins 8.
Assuming that you mean pins 2/3 and 5/6, here is what i have referenced to gnd with no signal into the amp
U300
pin 1 0.039
pin 2 0.007
pin 3 0.005
pin 5 0.003
pin 6 0.008
pin 7 0.007
U301
pin 1 0.027
pin 2 0.075
pin 3 0.073
pin 5 0.073
pin 6 0.031
pin 7 0.18
U302
pin 1 -0.021
pin 2 0.007
pin 3 0.007
pin 5 -0.007
pin 6 -0.022
pin 7 0.31
if i inject signal to the RCAs, at C355/R300 i get 0.045VDC and around -0.45VDC at the output (it grows in relation to the output swing).
Old 20th March 2013, 04:18 AM   #49
Yes. 2/3.
In the output photos above, it appears that you have about 30v of offset.
Am I reading the scope wrong?
Old 20th March 2013, 04:29 AM   #50
ultra's Avatar
How can you read it wrong?
the higher the output the greater the offset.
i may have not expressed it properly on #48
Rockford Fosgate T30001bdHide this!Advertise here!
rockford fosgate t30001bd dips1982 Car Audio 17 27th December 2013 10:01 PM
Rockford T30001bd shawnk Car Audio 22 25th March 2012 01:39 PM
Rockford t30001bd-big problem please help rezzyr Car Audio 3 21st September 2011 07:28 PM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
Rockford Fosgate T30001BD mike49504 Car Audio 71 26th March 2010 09:22 AM
