Rockford Fosgate T30001bd
Old 16th March 2013, 10:09 PM   #31
ultra is offline ultra
ultra's Avatar
yes i did
Old 16th March 2013, 10:24 PM   #32
Perry Babin is offline Perry Babin  United States
There isn't much in the amplifier that can cause a hum. That's typically caused by something connected to the mains. Are you sure that your signal source is not producing the hum?
Old 16th March 2013, 10:32 PM   #33
ultra's Avatar
I get the same noise even when the input RCAs are shorted to ground.
Old 16th March 2013, 10:36 PM   #34
Is the hum a 50/60Hz hum?
Have you tried a different signal source?
Old 16th March 2013, 10:46 PM   #35
ultra's Avatar
no, its a higher frequency noise.
it sounds like you hold a microphone and the wind is blowing.
shouldnt the amp be dead silent when i ground the RCAs?
i will try with a different source though
Old 19th March 2013, 09:28 PM   #36
ultra's Avatar
nothing changes with a different source.
i replaced all 8 op amps in the preamp section but i still dont get any output, only the loud hum.
Here is what i get at U300
pin 1 1.6
pin 2 0.01
pin 3 0.06
pin 4 -8.88
pin 5 1.54
pin 6 1.54
pin 7 1.54
pin 8 6.00
if i lift R300 and i inject signal to one end, i do get some signal on the output, but the hum is still loud.
However i noticed that the output swings between -2V to 0VDC.
First pic is what the signal looks like at Pin7 of U301
and the second one at pin2 of U401 (it is actually before and after R309).
Exactly the same applies to pin 7 of U302 and pin 2 of U400.
Old 19th March 2013, 09:48 PM   #37
MatthewS is offline MatthewS  United States
Send a message via AIM to MatthewS Send a message via MSN to MatthewS Send a message via Yahoo to MatthewS
Anyone feeling generous enough to send me a copy of the schematic to follow with?
linear8002@hotmail.com
Thanks!
Old 19th March 2013, 09:58 PM   #38
Received, thank you.
Old 19th March 2013, 10:14 PM   #39
Did you ever find the break in the feedback circuit? Because you said you checked traces, BUT the BDOUT is tapped BEFORE 'L400' so if you hardwired the connection on THAT side of the choke and there is still a break in the choke that output will never couple with the other phase which has it's own respective ties to the feedback system.
Perry is right, you can't ignore that break. I would check L400 to make sure NONE of those wires are snapped near the PCB, i've seen that on a few of these. The breaks like to hide sometimes under the glue too.
Old 19th March 2013, 10:22 PM   #40
ultra's Avatar
yes i have found the break, repaired it and the feedback now is as it should be.
Rockford Fosgate T30001bdHide this!Advertise here!
rockford fosgate t30001bd dips1982 Car Audio 17 27th December 2013 10:01 PM
Rockford T30001bd shawnk Car Audio 22 25th March 2012 01:39 PM
Rockford t30001bd-big problem please help rezzyr Car Audio 3 21st September 2011 07:28 PM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
Rockford Fosgate T30001BD mike49504 Car Audio 71 26th March 2010 09:22 AM
