Rockford Fosgate T30001bd - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 7th March 2013, 11:00 PM   #11
ultra's Avatar
It was climbing until it settled in 4.67Meg on one side and 4.68Meg on the other.
Old 7th March 2013, 11:24 PM   #12
It appears that there is a broken connection in the feedback circuit. The 3rd leg of that transistor should be directly connected to one end of R316.
Old 7th March 2013, 11:34 PM   #13
ultra's Avatar
ok, i will check that with my stereoscope and post back.
Would this destroy the fets had they been in the circuit?
Old 8th March 2013, 04:20 PM   #14
ultra's Avatar
I couldnt find that broken connection so i wired it underside the board.
Old 8th March 2013, 09:52 PM   #15
You need to find the break. It could leave another connection broken and sometimes the routing of the feedback line is critical.
Look at the diagram and check the connections from all 8 outputs that have either their drain or source directly connected to the BD_OUT.
Old 8th March 2013, 10:07 PM   #16
ultra's Avatar
in the area around the fets (where the copper traces are wider) all (drains and sources) appear to be ok.
Will try again though.
But, now i get the following readings on U301 and U302
U301
1. 4.70
2. 0
3. 1.54
4. -5.88
5. 0.102
6. 4.75
7. -4.10
8. 6.20
U302
1. 4.25
2. 0.245
3. 0.125
4. -5.88
5. 0.071
6. -4.23
7. 5.80
8. 6.20
I also grounded the source of each bank of fets (one at a time), and probed the gate
Old 9th March 2013, 11:12 PM   #17
What is the DC voltage on pin 7 of U300?
What is the DC voltage measured directly across the speaker terminals?
Old 9th March 2013, 11:36 PM   #18
ultra's Avatar
Pin 7 of U300 is around +4VDC.
Please note that when i took the amp in, i replaced that ic with a new one, as there was some work done on it that didnt look nice to me.
Across the output terminals i get 0.002VDC
Old 10th March 2013, 01:36 AM   #19
There shouldn't be any significant DC on that pin. Post the voltage on all pins of that IC.
IC300
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Old 10th March 2013, 03:33 PM   #20
ultra's Avatar
IC300
Pin 1: 3.66
Pin 2: 0.085
Pin 3: 0.100
Pin 4: -5.85
Pin 5: 4.00
Pin 6: 4.00
Pin 7: 4.10
Pin 8: 6.30
IC306
Pin 1: -4.25
Pin 2: -1.50
Pin 3: -1.60 (i know this is correct)
Pin 4: -5.88
Pin 5: 0.078
Pin 6: 0.090
Pin 7: 4.480
Pin 8: 6.30
IC307
Pin 1: 0.12
Pin 2: 0.099
Pin 3: 0.085
Pin 4: -5.88
Pin 5: 0.090
Pin 6: 0.086
Pin 7: 0.170
Pin 8: 6.30
rockford fosgate t30001bd dips1982 Car Audio 17 27th December 2013 11:01 PM
Rockford T30001bd shawnk Car Audio 22 25th March 2012 02:39 PM
Rockford t30001bd-big problem please help rezzyr Car Audio 3 21st September 2011 08:28 PM
Rockford Fosgate dtisme Car Audio 1 6th October 2010 12:39 AM
Rockford Fosgate T30001BD mike49504 Car Audio 71 26th March 2010 10:22 AM
Copyright 1999-2017 diyAudio
