MTX 1000D Problem
MTX 1000D Problem
Old 4th March 2013, 02:07 AM   #31
Exbass17 is offline Exbass17
i noticed there was 4 different secondary part #'s linked to the part # you gave me
Old 4th March 2013, 02:09 AM   #32
ok thanks Perry will do and beings i swapped a part i was unsure about i went with my power supply and a smaller speaker to be on the safe side
Old 4th March 2013, 02:10 AM   #33
so power the amp and check the voltages on the Outputs your saying?
Old 4th March 2013, 02:36 AM   #34
Perry Babin is offline Perry Babin  United States
The various parts have various levels of distortion. You can use the cheapest one.
Output pins of the op-amps, not the output transistors.
Old 4th March 2013, 02:41 AM   #35
would the expsensive one have a better distortion rate then and could i use that one?
Old 4th March 2013, 02:45 AM   #36
i dont have a amp meter if that is what your asking me to test
Old 4th March 2013, 02:53 AM   #37
No. I need you to measure the DC voltage on the output pins of all of the 8-pin op-amps in the amplifier. The output pins are 1 and 7. Pin 1 is near the white do on the board.
Old 4th March 2013, 03:02 AM   #38
ok ill check all the voltages of all the 8 pin op amps 1-7 and give you some readings also will it make any difference between using my power supply for readings vs my car battery
Old 8th April 2013, 01:03 AM   #39
bats101 is offline bats101
i hope i am in the right forum. i am replacing the bad mosfets on my mtx1000xd amp. and i have 2 Smt Type resisters burnt bad enough that they are unreadable R114 and R115. i need a schematic Cant locate ! i would appreciate some info...
Old 9th April 2013, 02:10 AM   #40
Please don't post in a repair thread that was started by someone else unless you are trying to help them.
Contact MTX. They will give you the resistor values.
MTX 1000D ProblemHide this!Advertise here!
mtx mxa8001 problem BEEFKING9 Car Audio 13 10th January 2018 12:17 AM
Help me fix my MTX 1000D, no sound, just static hakentt Car Audio 13 30th October 2009 05:33 AM
mtx 4250 problem firemedicsafd Car Audio 7 12th August 2009 08:34 PM
MTX 8302 problem damage Car Audio 46 27th October 2008 05:53 AM
mtx amp problem [[help!!]] fuzzypinkhat45 Car Audio 3 8th July 2008 06:34 AM
