Problem with Kicker Kx 500.2 Amp - Page 5 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 11th March 2013, 11:14 PM   #41
Is this the channel that you repaired?
Old 12th March 2013, 03:20 PM   #42
That is correct. It was the right side of the audio output that I repaired.
I also tested the +/- 15v pins and they are coming out in the mid 2v range.
Old 13th March 2013, 03:00 AM   #43
Remove the output transistors from that channel, clean up the solder pads to ensure that there are no solder bridges and see if the amp will power up.
Old 13th March 2013, 05:06 PM   #44
I removed the four output trnsistors from the right side audio. Amp powered up properly, then about ten seconds in a flash of light from board near right side output but no change in green light. Also volts at +/-15 are accurate again.
The part numbers i had installed in the spaces are as follows:
Q214-TIP35C
Q211- TIP35C
Q215-TIP36C
Q212-TIP36C
Are these the correct locations for the transistors?
That is the way they were installed prerepair.
Old 14th March 2013, 11:18 PM   #45
What do you mean by 'flash of light'?
Did something burn?
Was it a component or possibly a solder bridge?
Old 14th March 2013, 11:52 PM   #46
It was in the area of a component but from below all the solders look fine as do the components in the area of the flash.
Old 15th March 2013, 02:04 AM   #47
If the flash was in the area of a resistor, confirm that the resistors in that area are within tolerance.
Old 15th March 2013, 02:52 AM   #48
In the picture you provided the area that had the flash was in the lower right hand side of the picture under the metal bar. One of the pieces between 8 and 12 was where the flash came from. If these are the resistors how do i test them and what should the values be?
Old 15th March 2013, 11:28 PM   #49
You compare the resistance you read across them to their markings. If the difference between the readings and markings is greater than 5%, the resistor needs to be removed and checked. Since you have a second channel, you can compare the readings of the corresponding resistors in the two channels. If you don't know how to read resistor color codes, refer to the Resistors page of the car audio site.
Kicker Kx 500.2 Amp. Desafinado Car Audio 29 29th December 2012 08:31 PM
Kicker KX amp problems???? youngfix97 Car Audio 15 18th December 2012 11:21 AM
Kicker KX 600.4 amp 404Amps Car Audio 3 14th December 2012 08:23 AM
kx kicker 1500 timwebb Car Audio 14 22nd October 2012 07:36 AM
Kicker Amp Kx 600.4 Not Kicking MYLEY Car Audio 0 17th February 2006 03:11 PM
Copyright 1999-2017 diyAudio
