Go Back   Home > Forums > General Interest > Car Audio
Old 22nd February 2013, 11:02 PM   #1
Default Orion XTR 1500.1
Amp turns on, shows rail voltage, but does not produce audio. When the subsonic filter button or phase 0/180 degrees is pressed, the test woofer jumps. The woofer also jumps when turning the gain pot. All of these tests are done with NO rca input. I've also noticed a possible continuity problem when testing main ground to rca shielding.
Any starting help would be welcomed. [IMG]Click the image to open in full size.[/IMG]
Old 22nd February 2013, 11:29 PM   #2
Check all of the 10 ohm resistors on the outputs of the various regulators. In a similar amp, they commonly open.
Old 23rd February 2013, 03:44 PM   #3
are you referring to smd style resistors on the driver boards?
Old 23rd February 2013, 05:37 PM   #4
I don't have anything on this amp but the smaller version has a problem with the 10 ohm resistors on the output of the various regulators. They are highlighted with green arrows in the attached photo. They won't be exactly the same in your amp (or may not even exist in your amp). I think that there are at least 8 of them and maybe more.
Old 24th February 2013, 09:16 PM   #5
I believe that my tone generator had a dead batt at first test. The amp has output, sounds clean, still has turn off pop and pop when adjusting gain or depressing phase and subsonic.
Old 24th February 2013, 10:00 PM   #6
Are you turning it off by removing remove voltage (but leaving B+ and ground connected)?
Old 24th February 2013, 11:48 PM   #7
removing only remote turn on.
Old 24th February 2013, 11:52 PM   #8
Does the relay disengage precisely when you remove the remote voltage?
Old 25th February 2013, 02:25 AM   #9
All pins that I've tested that are driven by this circuit seem to be losing voltage at the time that I remove remote turn on
Old 25th February 2013, 10:07 PM   #10
Do you hear the relay disengage precisely at the point when you remove remote voltage?
Orion xtr-2250 mbates14 Car Audio 7 29th January 2013 01:36 AM
orion XTR 900/2 scampo77 Car Audio 18 31st May 2011 02:41 AM
Orion XTR 1400 NIM006 Car Audio 2 12th January 2009 02:11 PM
orion xtr 2150 mike49504 Car Audio 11 1st October 2006 12:19 AM
need help with a orion xtr 400 brax Car Audio 0 25th June 2004 07:26 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
