apmr-1504 audiopipe
apmr-1504 audiopipe
Old 22nd February 2013, 10:13 PM   #1
ian33 is offline ian33
Default apmr-1504 audiopipe
hi all
This amp is not powering up.PS FETs are not being turn on.
KA2535A pin 15 has pulsing .01 to .53v on it.All other pins is below .00v
pin 15 is connected to the emitter of MPSA 651.If i pull the emitter of this transistor from the board i get 11.71v on that leg. Any idea what to check?
LM393n
1pulsing 5.04
2: 5.39
3: pulsing 11.62
4: .00
5: 4.41
6: pulsing 5.28
7: 12.36
8: 12.71
Old 22nd February 2013, 10:44 PM   #2
ultra is offline ultra
ultra's Avatar
The outputs for 3525 are pins 11 and 14.
Do you have 12V on pins 13 and 15?
Does pin 16 has 5V ?
Old 22nd February 2013, 11:09 PM   #3
13 and 15 pulsing up to .53
no all other pins is .00v
Old 22nd February 2013, 11:14 PM   #4
ultra's Avatar
you need to track back the circuit from those two pins (13 and 15), and see where you loose the 12V.
If those two pins (13 and 15) have no power (12V), the ic is not operating at all.
Old 23rd February 2013, 12:05 AM   #5
the 12v is not missing,I think something is draging it down
Old 24th February 2013, 01:00 AM   #6
any one have a schematic diagram for this amp?
Old 26th February 2013, 03:33 AM   #7
I remove the ka3525 and pin 13 an 15 has 12.23v on them.
I install sg3525an and there is no voltage again.I also replace the LM393
but no change.I think the pwm ic drive the FET direct.Any idea what the problem might be?
Old 27th February 2013, 12:37 PM   #8
Perry Babin is offline Perry Babin  United States
The 12v has to be present but also has to have enough current capacity to maintain the 12v. If the voltage is dropping and nothing is getting hot, it's likely that the 12v source has too much resistance. You will have to find the component feeding the 12v to the 3525. When you find it, let us know what it is and we'll help you troubleshoot from there.
Old 27th February 2013, 11:09 PM   #9
Its a transistor MPSA 651
Old 28th February 2013, 12:53 AM   #10
Post the voltage on all 3 legs when the voltage is being dragged down.
apmr-1504 audiopipeHide this!Advertise here!
Audiopipe ap30001d blazer40 Car Audio 15 4th October 2012 02:27 AM
Audiopipe AP10001D mike49504 Car Audio 18 16th August 2011 12:36 AM
Audiopipe AP-15001D mike49504 Car Audio 8 29th July 2011 08:55 PM
1500 audiopipe timwebb Car Audio 2 5th April 2011 11:44 PM
Audiopipe AP15001D . In need of an inductor spooney Car Audio 14 24th January 2011 11:05 PM
