Rockford Fosgate Power 650
Old 23rd February 2013, 05:47 PM   #21
RockfordFIx is offline RockfordFIx  United States
Wht do you think perry?
Old 23rd February 2013, 06:33 PM   #22
Perry Babin is offline Perry Babin  United States
Correct me if I'm wrong but I think the 650s all used bipolar transistors in the power supply, not FETs.
Old 23rd February 2013, 06:52 PM   #23
seankane is offline seankane  United States
seankane's Avatar
They used D44VH10 which were a power transistor, 15A-80V-83W and were not bipolar.
They did however also use a couple D45VH7 in the power supply which were bipolar general purpose transistors.
I am not sure why the mix, and these transistors are not FETS like the IRF3205 so I do not believe the IRF3205 would work.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 23rd February 2013, 07:27 PM   #24
The D44VH10 is a bipolar junction transistor. Look at the description at Mouser:
D44VH10 ON Semiconductor | Mouser
Old 23rd February 2013, 07:28 PM   #25
seankane's Avatar
I stand corrected, the data sheet I used did not specify that.
Old 23rd February 2013, 07:28 PM   #26
NPN/PNP are BJTs.
N-channel/P-channel are FETs.
Old 23rd February 2013, 07:30 PM   #27
seankane's Avatar
Right so the IRF3205 will not work in this application.
Old 23rd February 2013, 07:35 PM   #28
There are some drive circuits that can drive FETs, even though they were intended to drive BJTs. I don't know if that's the case here. I would use the original part number. The supplies in these amps were reliable as designed.
Old 23rd February 2013, 07:38 PM   #29
seankane's Avatar
How do you determine if an originally designed BJT supply is able to drive FETS?
Old 23rd February 2013, 07:46 PM   #30
BJTs can be driven by a relatively low amplitude signal since they have a threshold of about 0.6v. FETs require a drive signal with a much greater amplitude. The threshold voltage for an FET is about 3.5v but they are generally driven with a signal that has an amplitude of about 10v (ground to +10v) to ensure that they're fully 'on'.
You can look at the amplitude of the signal to see if it's close to what the FETs need but that's not definitive as to whether they would work. I tried using FETs in an old Orion that used BJTs and even after modifying the drive circuit to get the right signal, they wouldn't work. The amp would work but the 12v primary filter caps would fail after just a few minutes at full power. After removing the drive mods and installing BJTs, the amp worked perfectly and the primary caps didn't overheat.
Rockford Fosgate Power 650Hide this!Advertise here!
Rockford Fosgate Power 650 shawnk Car Audio 43 10th April 2015 05:36 AM
Rockford Fosgate Power 650 seankane Car Audio 82 6th February 2013 10:38 AM
Rockford Fosgate Power 650 Mosfet "rejuvification" pgerry Car Audio 16 20th October 2012 03:25 PM
rockford fosgate power 650 mosfet mike49504 Car Audio 43 24th March 2011 11:21 PM
Help with Rockford Fosgate Power 650 shawnk Car Audio 31 14th July 2010 09:11 PM
