Clarion DPX11500 #2 Repair - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 20th February 2013, 05:00 AM   #21
Yes, it does become greater, I checked the centre pin of each transistor. I had no problem pushing the voltage up to 40V+
Old 20th February 2013, 07:37 AM   #22
To clarify, the +25 goes to +40 and the -25 goes to -40?
Old 20th February 2013, 11:44 AM   #23
Yes, that is correct.
Old 20th February 2013, 12:19 PM   #24
What is the resistance between the emitter leg of any output transistor and the positive speaker terminal?
Old 21st February 2013, 12:02 AM   #25
Sorry for the late reply.
I get .1ohm.
Old 21st February 2013, 05:47 AM   #26
Previously, you stated that the output was distorted and there was about 1v across the speaker terminals. Was the 1v there with a speaker connected or did it drop to 0v?
Was it distorted but very loud?
Did you try it without the limiter, confirming that there was 12v+ across the B+ and ground terminals?
Old 21st February 2013, 07:40 AM   #27
Hi Perry, thank you for your help this far.
To answer your question I tried your suggestion.
The distortion is fairly loud, as in louder than the actual music playing. (however in real world application I might not hear it installed) I cautiously powered the amp up tonight with a fuse instead of the limiter, (voltage was 12V at the amplifier power terminals) and the output is the same. Without music playing but source hooked up, I would have to describe the sound as "white noise"
I made a sample video of the output with source playing.
http://www.youtube.com/watch?v=sQ1SH4J5SaI
It should be noted, that the DC output starts around 1.2VDC but slowly drops. for example, tonight it had dropped to about .75 before I disconnected the power supply.
Old 21st February 2013, 03:34 PM   #28
I don't understand. How is installing it when it's in the vehicle going to make the audio less distorted/noisy if the noise is louder than the music?
What are you using for a signal source?
Where was the black probe when you measured the DC voltage on the speaker terminals?
Old 21st February 2013, 03:42 PM   #29
My apologies, it was quite early in the morning when I wrote that. What I said does not make sense.
When I test for DC voltage I am placing the black probe on the negative speaker terminal.
Is this incorrect?
I am using my Ipod for my source.
Old 21st February 2013, 06:44 PM   #30
Using the negative speaker terminal was correct.
??>> I don't understand. How is installing it when it's in the vehicle going to make the audio less distorted/noisy if the noise is louder than the music?
Clarion Dpx11500 repair help Zeptoplix Car Audio 19 15th February 2013 06:58 PM
Clarion DPX11500 Repair Help Zeptoplix Solid State 0 21st January 2013 08:38 PM
Clarion DPX11500, MPS651/751 m4ick Car Audio 3 18th May 2011 10:55 PM
Clarion DPX11500, can't read gate resisitors m4ick Car Audio 2 16th May 2011 01:52 PM
Clarion DPX11500 m4ick Car Audio 1 12th April 2011 03:37 PM
Copyright 1999-2017 diyAudio
