Polk Audio PA880
Polk Audio PA880
Old 19th February 2013, 07:23 AM   #11
Perry Babin is offline Perry Babin  United States
The 4558 isn't likely to be used to supply power to the power supply IC. It may drive a transistor that drives voltage to the PS IC but it won't drive it directly. The voltage is likely supplied via the collector of a PNP transistor.
Old 22nd February 2013, 09:17 PM   #12
S Merlington is offline S Merlington  United States
I found a B647 that deliveras the 12 volts to pin 8,11,12..
Is there a good sub for the B647 ?
Old 22nd February 2013, 09:28 PM   #13
BD140
Old 22nd February 2013, 09:39 PM   #14
Replaced that same problem only 2 volts on pin 8..
There are only 2 other transistors in that area A1015's
If i find 1 to be defective is there a good replacement for thoose?
Also there is a diode connected to pin 8 (ZD1) 1 side has 2 volts other side is 0.00 volts and 2 volts measured directly across it..
I that normal and i need to back track more?
Old 22nd February 2013, 09:50 PM   #15
Post the DC voltage on all 3 legs of the transistor.
Old 22nd February 2013, 09:54 PM   #16
Leg 1:13.90
Leg 2:13.60
Leg 3:13.10
Old 22nd February 2013, 09:58 PM   #17
Either that transistor doesn't go to pin 8 or the voltage you read on pin 8 was wrong.
Old 22nd February 2013, 10:08 PM   #18
There is an A1015 transistor the voltage on that is
Leg 1:13.80
Leg 2:0.8
Leg 3:13.90
Old 22nd February 2013, 11:23 PM   #19
Do you see a 0 ohm connection to either of these transistors from pin 8, 11 or 12?
Old 22nd February 2013, 11:59 PM   #20
The middle leg of the BD140 connects to a 100 ohm resistor then goes to pins 8,11,12..
If i place one probe on pin 8 and the other probe on the middle leg of the BD140 i get 100 ohms on pin 8 ..
So im assuming that the BD140 is connected to pin 8
I get 13.89 volts on 1 side of the 100 ohm resistor but only 2.74 volts on the other side..
Could the 494 possibly be bad?
Polk Audio PA880Hide this!Advertise here!
Polk Audio sub PSW111 michaeleanor Subwoofers 3 27th September 2014 12:53 PM
Need HELP!!!! POLK AUDIO MONITOR 30 msj965 Multi-Way 5 26th February 2011 05:39 PM
Polk Audio sexya Full Range 21 12th November 2009 02:22 PM
Polk Audio Sub? samsagaz Subwoofers 4 22nd January 2007 02:51 PM
JL Audio vs Polk Audio xfsrg Car Audio 2 17th October 2004 06:09 AM
