rockford fosgate power 1001 bd
Old 19th February 2013, 03:25 AM   #41
seankane is offline seankane  United States
seankane's Avatar
u5
1:0
2: 8.33
3: 8.26
4: -9.61
5:0
6: -7.32
7: 9.83
8:0
Are you sure about pin #2? Its a ground, wondering why you have positive voltage on it?
Pin #6 has DC on the output pin.
This IC may be defective.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 19th February 2013, 03:31 AM   #42
seankane's Avatar
U15 and U6 look OK, not 100% on U15 you may want to see what Perry says.
Old 19th February 2013, 03:31 AM   #43
amp it up is offline amp it up  United States
Yes pin #2 has 8.33 I will change out that IC real quick.
Old 19th February 2013, 03:34 AM   #44
seankane's Avatar
What does U7 read on all pins?
Old 19th February 2013, 03:43 AM   #45
U7
1:0
2: 8.26
3: 0
4: -9.61
5: 0
6: 8.29
7: 9.88
8: 0
Old 19th February 2013, 03:45 AM   #46
I switched out the IC and the voltages are the same.
Old 19th February 2013, 03:50 AM   #47
I tried audio through it again and still distorted!
Old 19th February 2013, 04:03 AM   #48
seankane's Avatar
U7
1:0
2: 8.26
3: 0
4: -9.61
5: 0
6: 8.29
7: 9.88
8: 0
This IC has no + input voltage on pin #3 as it should, and has + voltage on the negative input.
Old 19th February 2013, 04:11 AM   #49
Ok i will change it out
Old 19th February 2013, 04:19 AM   #50
OK still the same voltages.
rockford fosgate power 1001 bdHide this!Advertise here!
Rockford Fosgate T1500-1 BD josesony68 Car Audio 42 21st May 2016 01:53 PM
Rockford Fosgate T40001 BD Help scotts530 Car Audio 5 1st February 2012 06:01 AM
Rockford Fosgate BD 1000 mike49504 Car Audio 1 10th July 2011 10:54 PM
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
rockford fosgate 1500 bd mike49504 Car Audio 18 30th December 2008 07:37 AM
