Rockford Fosgate 800.4 - Distortion Ch RR - Page 7 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 21st March 2013, 08:58 AM   #61
Witwe is offline Witwe  Germany
hmm....all 4 channels have the same problem with the Highpass...
Here is how the signals looks like with the scope at 5V/div:
Pin7 U300-U303 with the gainpot at minimum
Pin7 with the gainpot at higher volume (1/3 turn cw)
U300-U301
U302 (this seems to be the lowpass, right?)
U303 (a little deformed)
Pin1+7 with the gainpot at high volume (1/2 turn cw)
U300-U301 (is that normal????)
U303 Pin1
U303 Pin7
or are the bias pots still set incorrectly?
I started with them at full ccw. (the amp draws 1,25A)
Then I slowly increased them till the amp draws a little more current (~1,29A)
And then I set it a little back to about 1,27A.
Old 21st March 2013, 08:30 PM   #62
Do you have perfectly clean output from channels 1 and 2 with the crossover set to high-pass?
Has any work been done to the ch3/4 crossover section of the amp?
Old 21st March 2013, 08:57 PM   #63
channel 1 and 2 are looking as bad as 3 and 4 with the high pass crossover set.
but at full range, all channels looks clean...
no I havn't done anything to the crossover, but I don't know if the previous owner has done anything. (my brother bought it from ebay and has never used the crossover)
should I check all the resistors for the correct value or can it be anything other?
Old 21st March 2013, 09:17 PM   #64
There may not be any problem. Sometimes, crossovers will cause the signal to appear to be distorted when it's not. Does it sound OK in high-pass?
Old 21st March 2013, 09:29 PM   #65
ok?
I will test it out tomorrow and Keep you informed.
and the Signal at Pin1+7 from U300-U301 is normal?
Old 21st March 2013, 09:34 PM   #66
Without the scope settings, it's impossible to determine if that's normal.
Old 21st March 2013, 09:57 PM   #67
5v/div
with the volume a Little lower it Looks like this:
this relates to all 4 channels.
Old 21st March 2013, 11:43 PM   #68
That is OK. You were over-driving the preamp section causing the op-amps to clip.
Old 27th March 2013, 06:31 PM   #69
back in the car the amp plays fine
thank you very very much for all your help and patience!!!!
My brother is very happy now. (2 month without music was a hard time for him =)
Old 25th June 2014, 09:08 PM   #70
jessemx is offline jessemx  United States
did you ever find the problem, I have the same issue but on an 800.2a , hope to get fix soon. :-(
Rockford Fosgate Punch 800.2 seankane Car Audio 104 10th December 2012 01:13 AM
Rockford Fosgate Power 800.4 seankane Car Audio 71 17th January 2012 07:43 PM
Rockford Fosgate 800 a2 mike49504 Car Audio 1 8th July 2011 06:33 PM
Rockford Fosgate 800.2 Brain Fried Car Audio 2 16th April 2010 05:14 PM
Rockford Fosgate Power 800.4 lostamps Car Audio 6 2nd January 2008 12:21 PM
Copyright 1999-2017 diyAudio
