Rockford Fosgate 800.4 - Distortion Ch RR - Page 4 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 1st March 2013, 06:26 AM   #31
Witwe is offline Witwe  Germany
the klick while powering up the amp (like you can see at the scope video) is away.
the DC Voltage at Idle:
RL - 11,3mV
RR - 17,1mV
LF - 5,6mV
RF - 1,3mV
but when disconnecting the power, all channels still increase dc voltage to 300mV like before. or is that normal?
Old 1st March 2013, 09:14 PM   #32
You should not have 300mv of DC on all channels. Are you measuring the DC voltage directly across the two speaker terminals for each channel.
I don't watch the videos people post.
Reconnect those two transistors. Remove Q316. Post the DC voltage on all legs of Q300-Q304.
Old 2nd March 2013, 11:43 AM   #33
yes, directly across each speaker terminal!
is that wrong?
DC Voltage:
Q304
B : 12,75V
E : 13,37V
C : 11,6V
Q303
B : 12,75V
E : 13,39V
C : 12,75V
Q302
B : -29,9V
E : -646mV
C : 12,75V
Q301
B : -33,1V
E : -645mV
C : 12,52V
Q300
B : -7,06V
E : -7,73V
C : -685mV
Old 2nd March 2013, 02:00 PM   #34
Directly across the speaker terminals is the right way to check the DC offset.
Re-check the DC voltage on the bases of Q301 and Q302. These should be very near 0v. Compare the voltage to the voltage on the bases of the corresponding transistors in the other channels.
Old 4th March 2013, 11:47 AM   #35
Ahh, sorry. i have missed the mV....
here the measurings again:
Q304
B : 12,75V
E : 13,37V
C : -11,57V
Q303
B : 12,75V
E : 13,39V
C : 12,75V
Q302
B : -30,6mV
E : -648mV
C : 12,75V
Q301
B : -33,3mV
E : -645mV
C : 12,52V
Q300
B : -7,06V
E : -7,73V
C : -685mV
i have compared everything with Q400-Q404 but with Q416 in circuit.
Q404
B : 12,77V
E : 13,40V
C : -11,55V
Q403
B : 12,77V
E : 13,42V
C : 12,77V
Q402
B : -40,5mV
E : -653mV
C : 12,77V
Q401
B : -35,6mV
E : -652mV
C : 12,55V
Q400
B : -7,06V
E : -7,73V
C : -693mV
I have also compared it to the bases of the other channels:
Q101
B : -35,8mV
Q102
B : -38,2mV
Q201
B : -37,8mV
Q202
B : -38,5mV
Old 4th March 2013, 06:07 PM   #36
I don't see a problem.
When you saw the distorted signal on the scope (with Q316 in the circuit), was a speaker connected to the channel?
Does the bias pot cause an increase in current draw in the 300 series channel? The transistors must be clamped when you check this.
Old 5th March 2013, 06:09 AM   #37
there was no speaker connected during the test:
when I connect a speaker, the signal looks like this
the bias pot don't increase the current much.
full ccw: 1,27A
full cw: 1,39A
the other channels increase the current draw over 11A when setting there bias pots!
Old 5th March 2013, 03:48 PM   #38
Does it produce a clean audio signal with Q316 out of the circuit and a speaker connected?
Old 6th March 2013, 05:54 AM   #39
yes it does!
Old 6th March 2013, 12:08 PM   #40
What is the DC offset across the speaker terminals with the speaker/load connected?
Rockford Fosgate Punch 800.2 seankane Car Audio 104 10th December 2012 01:13 AM
Rockford Fosgate Power 800.4 seankane Car Audio 71 17th January 2012 07:43 PM
Rockford Fosgate 800 a2 mike49504 Car Audio 1 8th July 2011 06:33 PM
Rockford Fosgate 800.2 Brain Fried Car Audio 2 16th April 2010 05:14 PM
Rockford Fosgate Power 800.4 lostamps Car Audio 6 2nd January 2008 12:21 PM
Copyright 1999-2017 diyAudio
