Rockford Punch 45
Rockford Punch 45
Old 6th February 2013, 03:34 AM   #1
seankane is offline seankane  United States
seankane's Avatar
Default Rockford Punch 45
Hello have an older Punch 45 before they had fuses.
It had a shorted output. I removed the shorted output and the amp powers up and produces audio on the remaining good channel.
Dont have a schematic need to know what the burned resistor is next to the white power wire. I assume it burned while the amp was drawing current from being powered with a shorted output.
Can I replace MTP12P05 with IRF9540?
Can I replace MTP3055A with IRF540?
I have 200 MTP3055E in stock not sure if they are the same as the "a" version?
I can still order the MTP12P05 but I think I would rather use the 540/9540 if they will work in this amp??
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 6th February 2013, 03:42 AM   #2
Perry Babin is offline Perry Babin  United States
The resistor is likely OK. It's a 120 ohm.
The 540/9540 would be my choice.
Old 6th February 2013, 04:21 AM   #3
seankane's Avatar
Thanks.
Old 11th February 2013, 06:53 AM   #4
seankane's Avatar
Replaced the outputs, amp works great.
Can you tell me what year this model is?
Old 11th February 2013, 07:39 AM   #5
I don't know the exact year but if that's the date code on the op-amp, the op-amp was manufactured in the 12th week of 1987.
Rockford Punch 45Hide this!Advertise here!
Punch 45 yo0 Car Audio 7 28th September 2012 03:17 AM
Rockford fosgate punch 45 power supply repair help chipper Car Audio 16 15th November 2011 11:11 PM
Rockford fosgate punch 45 no output chipper Car Audio 37 18th October 2011 06:25 AM
kicker zr1000, orion hcca 250r, mmats d800.2, mtx6500d, mtx 942, rockford punch 45 ernie cosillos Swap Meet 2 16th February 2011 05:56 PM
orion hcca250r, kicker zr 1000, mmats d800.2, mtx 6500d, mtx 942, rockford punch 45, ernie cosillos Swap Meet 3 12th February 2011 11:14 AM
