#21 |
6 amps current should get you by for basic testing and low power testing. I only use a 15 amp rated unit myself for everything except power testing amps to see if they perform to rated spec or not.
![]() PS set that supply at 14.4 volts which should the cold rated charging voltage of your vehicle. You can use 12 volts to imitate a battery type supply but when ever the motor is running the amp will likely see 13.85 to 14.4 volts Dc which is the charging range of your alternator system. |
| Rumble filter | LAJ | Music | 0 | 24th November 2010 05:08 PM |
| Turntable rumble? | bereanbill | Analogue Source | 4 | 4th May 2009 08:57 PM |
| Rumble Filter | soloxp | Subwoofers | 5 | 27th July 2006 12:02 PM |
| Pioneer DEH-P8600MP, Infinity Kappa 693.5i, and Infinity Reference 6402cfp, and more | jawglasswell | Swap Meet | 0 | 13th March 2005 07:38 PM |
| Turntable rumble | lordvader | Analogue Source | 10 | 1st April 2002 11:26 AM |
