Go Back   Home > Forums > General Interest > Car Audio
Old 1st February 2013, 07:22 PM   #31
seankane's Avatar
Just scored another 25 D41D8 transistors from a gentleman in Canada at a very good price.
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 3rd February 2013, 12:07 AM   #32
shawnk is offline shawnk  United States
Originally Posted by Perry Babin View Post
You now need to test it with a load (all transistors clamped, fan not necessary because you need it to heat up). Let it heat up about 10° and see how the idle current has changed.
Done! I just drove the amp (both "repaired" channels 4 ohm load each) with a sinewave for a good 20 minutes and let the amp warm up significantly.
The amp drew ~1.5A at idle when first fired up (cool to the touch) and after the 20 min run, current draw only icreased by ~0.25A. So even when warmed up idle current was still less than 2A. After the run, the output pins for each op-amp remained clean/flat and there was no more dc offset present.
This is all great, but I'm just wondering why the amp is acting differently than my previous testing. I haven't done anything different to it other than present a load.
Old 3rd February 2013, 12:08 AM   #33
Nice score!!!
Old 3rd February 2013, 12:44 AM   #34
seankane's Avatar
DC can do wierd things in these old amps. Sometimes these amp are stable and sometimes they are haunted....lol!!!
I have 2 brand new bottom covers for these amps and I noticed you had a green board version which was the last models before they were discontinued. My 4 power 650's were all the older models with the DIN which I removed and replaced with RCA jacks of course.
The selector switch for 4 channel and 2 channel must be different on the later models, like a very small switch. The hole in the sheet metal I have is very small and cannot accomedate the older version slide switch.
I was wondering if you could post a pic of the switch on your board and the bottom cover where the switch comes through???
Old 3rd February 2013, 12:55 AM   #35
seankane's Avatar
Just scored another 250 D40D8 transistors for a good deal.
Old 3rd February 2013, 03:16 AM   #36
Sure man. I'll snap a couple pics in the morning for you.
I have two of these 650's here. One "newer" one has the green board and the shroud has the larger 4" fan.
I also have an older one which is the one giving me a hard time
Old 3rd February 2013, 04:56 PM   #37
Pics for Sean! Let me know if you need any others bud...
Old 4th February 2013, 06:09 AM   #38
seankane's Avatar
No thats perfect, the bottom covers I have are still different. Maybe they were a defect?
Where the 2 channel/4 channel switch is it is a very small opening. Maybe like they were going to give the 650 a facelift an modernize it a little then came up with the DSM's and bagged it.
These are brand new bottom covers. I could modify them to work, be nice to find a switch that would work with the slot that is cut ya know?
Old 4th February 2013, 10:19 AM   #39
Sean, give us a few pics of these bottoms.
Old 4th February 2013, 11:21 AM   #40
yeah.... please do. Inquiring minds want to know
Rockford Fosgate Power 650 seankane Car Audio 82 6th February 2013 09:38 AM
Rockford Fosgate Power 650 Mosfet "rejuvification" pgerry Car Audio 16 20th October 2012 02:25 PM
Rockford Power 650 Mosfet seankane Car Audio 16 7th September 2011 07:17 PM
rockford fosgate power 650 mosfet mike49504 Car Audio 43 24th March 2011 10:21 PM
Help with Rockford Fosgate Power 650 shawnk Car Audio 31 14th July 2010 08:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
