Punch45 Constant Noise from right channel-? - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 31st January 2013, 10:34 PM   #11
Satyr is offline Satyr  United States
Default Photos won't load
I've spent the last 3 hours trying to post photos of the P45s board to this thread- and even though they are sized properly- it's a no go. The pictures are in my "gallery" in diyaudio, however so...
Here's a link to the photo of the board in my gallery:
Old 31st January 2013, 10:37 PM   #12
Sigh. Ok then, here's a macro shot of the side with burns...
Old 31st January 2013, 10:44 PM   #13
It appears that you allowed an unfused remote wire contact one of the speaker wires. What color wire connected to that terminal of the plug?
Old 31st January 2013, 10:47 PM   #14
One last macro of the burned side. Used 2 desk lamps and no flash to try and get light while eliminating glare.
No, the transistors weren't clamped- just the aluminum plates were in place behind them. The whole thing took about 3 seconds to go from crackling static like before, to smoke and burns on the traces...
Old 31st January 2013, 10:59 PM   #15
I'm sure you're both right (and a genius.) The old electrical tape I had wrapped around the remote turn on lead had fallen off- and while the speaker wire connections were covered, they were not covered real well- because the tape is losing adhesion. So it is entirely possible it made contact with either the black or orange wire... (forehead slap)
Old 31st January 2013, 11:01 PM   #16
Look at the pin that's connected to the burned trace. Does that go to the black or the orange wire?
Old 31st January 2013, 11:09 PM   #17
So, in your opinion, what sort of prognosis do you think this amp has?
Old 31st January 2013, 11:13 PM   #18
Looks like the burned area on the left side goes to the black wire.
Old 31st January 2013, 11:26 PM   #19
That's not one of the active speaker wires so the output transistors may have survived. You may not need to do anything other than repair that trace (if it's actually burned open) to get back to where you were.
Please read the basic repair page (link in sig line below), paying special attention to the information in the yellow box.
Old 1st February 2013, 05:04 AM   #20
OK- thanks for the help. I'll try and pick up here soon.
TDA1541 - noise in one channel? phofman Digital Source 6 17th October 2016 10:57 AM
N-channel JFET + multiturn trimming potentiometer = variable constant current diode? Groundloops Parts 4 26th February 2012 05:50 PM
My first amp: constant white noise problem simsim Chip Amps 13 10th March 2008 07:49 PM
Right Channel Noise cwoodall Solid State 4 29th June 2006 06:25 PM
Review - TC622VAT: Fan-cooling amps without the constant noise OddOne Chip Amps 0 22nd May 2004 10:15 PM
Copyright 1999-2017 diyAudio
