Helow who can help me LightningAudio2000
Old 31st January 2013, 05:58 PM   #11
IoNuTz1 is offline IoNuTz1  Romania
Send a message via Yahoo to IoNuTz1
No reply from latech@lightningaudio.com
No one have Lightning audio storm x1.2000.1D ???
Old 31st January 2013, 06:28 PM   #12
Perry Babin is offline Perry Babin  United States
If I'm not mistaken, Rockford has the same tech support people as Rockford. Try contacting Rockford for the schematic diagram.
Old 2nd February 2013, 11:23 AM   #13
Why only that mosfet transistor is heat end broking what to check ????
its mark with black end red
Old 2nd February 2013, 02:22 PM   #14
Is the gate resistor within tolerance for that FET?
Do you have a bad solder connection or a broken trace on the gate leg of that FET?
Are these new FETs? If so, if you swap it for one in another location, does the heating follow the FET or does any FET in that location heat up?
Old 2nd February 2013, 02:44 PM   #15
Not all new only 2 on that part.
I put a new one in the place but she heat.
The connection i think its good.
With multimeter can check.
Old 2nd February 2013, 02:47 PM   #16
Post the resistance between the first and second legs for each of the transistors in that half of the power supply (8 total).
Old 2nd February 2013, 07:12 PM   #17
Sorry with what masseur resistance .
Could you make a mark on the picture?
Pretty please.
Thank you very much.
Old 2nd February 2013, 07:30 PM   #18
See attached.
Old 3rd February 2013, 09:24 AM   #19
Measured the feet of the image in black and red.
I written values ​​in the image.
Transistors are IRF3205.
I measured directly on board.
Old 4th February 2013, 03:00 AM   #20
The ones that read significantly less than 100 ohms are defective. All of them need to be replaced.
Helow who can help me LightningAudio2000Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
